Thread: Which one
    Jul 2011
    UK
    Year : 06
    Default Which one
    To adjust to beam to heighten and which way do I turn it here a pic of drivers side
    Sent from my Desire HD using Tapatalk
    Nov 2009
    N/A
    Quote Originally Posted by marc vectra sri View Post
    http://img.tapatalk.com/5c0cfeb2-b7dd-20ae.jpg
    I'm guessing there the same, on mine, which direction etc is actually moulded into the plastic, not next to the adjusters, but on the far outside edge of the unit, right by the lenses
    Can't remember which way, but it's the inner of the two screws adjusts the beam height. ie, the screw nearest the radiator grille (if it's facelift headlights)
    Be careful as it's quite a coarse adjustment. ie, a small amount of turn makes quite a bit of difference in higher or lower settings.
    Jul 2011
    UK
    Year : 06
    So be the one on the left of the pic to height. Id say really turn it clockwise to go up
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    iirc, yes, it's the inside one of the two. Surely, if you're lining it up on a flat surface, turn it, if it's wrong, turn it back?
