Thread: gear stick replacement
    Regular Member prokie's Avatar
    Dec 2011
    southport
    Eek gear stick replacement
    ok so my gear knob abit worn so ive just got a whole thing out of another 2.2 my mate was breaking.
    you all know whats coming, how do i get the old 1 out and the new 1 in
    the new 1 is the whole thing with the black casing and 4 screw holes on the bottom of it and it even has the cables runnin to the shaft wich takes me to another question, how do i get the 2 cables of the new gear stick so i can some how clip my old cables to it that run throug the car
    any help is much appreciated
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Can't you just change the knob? Do you need to do all of it?
    Dec 2011
    southport
    been told you cant change the knob it needs to be the whole thing
    Full Member spennny's Avatar
    Blantyre
    It's easy to do mate , have a search on here under my name or VXR gear knob , should take you 20 mins :-)
    Dec 2011
    southport
    Quote Originally Posted by spennny View Post
    jus had a look at your post and being fair you make it sound really easy lol. what do i do with that other cable to get it of though? not the ball joint one the one on the side
    Blantyre
    Quote Originally Posted by prokie View Post
    What other cable mate ? Mine is a 2.2 Direct and am sure there is only one cable lol
    Blantyre
    Do u have the other one out , can you stick up a pic
    Dec 2011
    southport
    theres one connected to the bottom of the gear stick on the ball joint and another one to the left of it as well
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Take out the trim and lift up the gaiter.
    According to Haynes, you make room by taking out ash tray etc so you can disconnect the cables from the gear stick. (You can probably see on your replacement how to disconnect the cables). You then unto the 4 bolts and out comes the old one. Install the new one (without the cables) then connect the cables, The tricky bit is to get the correct adjustment on the cables - there are some sort marks where the cables connect to the gear box, under the bonnet. Set the gearstick to match the marks and tighten the cables and test.
    Dec 2011
    southport
    Quote Originally Posted by Dal5band View Post
    and heres me thinkin it was going to be a 5 minute job, gonna ave a go at tacking it this weekend and see how far i get
  1. Anyone know if this is the whole gear stick?
    By ronnie63 in forum Styling
    Last Post: 22nd January 2013, 18:02
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
  4. Gear stick Insert replacement
    By aps in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2009, 09:40
