Thread: swirl flaps
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default swirl flaps
    What position do the swirl pots need to be to be in the open position?
    My bar has come off and the pots seems to be sitting at 11o'clock and the 3rd one that is powered by the actuator is sitting at 12 o'clock.
    Jan 2008
    ipswich
    i dont know mate all i knew when i took mine to vauxhall i had to have a complete new manifold or you can put the bar bk on yourself but its a hard old job i got told
    Kildary, Highland
    Open is between 4 and 5 o'clock, closed between 7 and 8 o'clock. If the bar's off they'll be all over the place with vibration. If the flap controlled directly by the actuator got jammed and then released, the linkage under the manifold might have got damaged so that could explain that one.
    West
    open is 10 oclock... with the engine off you will see pot 3 is facing 10 oclock... that is open
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine have been glued open for about 10k miles now. I used the attached pic to keep them open, and seal around the valves as there was movement. Now no oil leaking, all bone dry and car runs like brand new
    West
    Quote Originally Posted by tony-1977 View Post
    Likewise
    Have you blanked the egr? all i have done is unplug it, i have a code reader & i can live with the light on
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Likewise
    I ordered an oval EGR blank off eBay this morning. The one with the 9mm hole to stop the light coming on
    ---Sent from my iPhone 4 using Tapatalk
    Aug 2011
    Basingstoke
    Trim : SRI
    What position is open?
    West
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by justin32 View Post
    10 o'clock
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  3. Swirl flaps
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 19:13
  4. Swirl Flaps Pt 2
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 18:43
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
