Results 1 to 10 of 11
Thread: cd 70 nav
    Apr 2011
    england
    Default cd 70 nav
    hi all
    was wonderin if any 1 could help me or put me in the right direction with a little problem i ave with my cd player (cd70)
    wen playin a music disk a original or a copied disk burnt at a slow speed and try many different types of disk
    after a while of playin the disk it errors out or says invalid disk and spits it out and the disk is very warm , sometime it will play wen ya put it back in . i ave try puttin a different disk in (a cold 1) which will play for a little while then the same thing happens again
    i was wonderin if it was the laser at fault or the cd player part breakin down and is it repairable or time to get a new
    the player is in a vectra 2006 2.2 sri and is cd 70 navi
    hope someone can help many thxs in advanced
    flipjim
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Maby the cooling to the CD70 isnt working..
    Apr 2011
    england
    hi ya kenp thxs for ya reply
    how do i find the cooling to the cd70 never knew there was 1 and is it easy to get to check this
    many thxs for the reply
    Engine : 2.2 Direct
    when you take out your screen and vents.. theres a plastic thing.. connected to the cage, that cools it down.. (its going to the heater matrix), and maby the radio also has its own fan (i dont know that for sure)
    Apr 2011
    england
    hi again i ave found the fan in the unit itself
    i not sure but i think it could be that goin to play the cd player till
    it errors out then check it but its lookin like that it could be that fan and not the 1 on the matix system but will ave a check at that aswell
    many thxs for ya help
    Engine : 2.2 Direct
    The matrix is just some tubing thats cools the cover..
    But if it overheats.. then its natural it works when it gets something "cold" inside.
    Apr 2011
    england
    hi again
    i ave got to the fan inside the the cd player and disconnected the power from the unit itself and powered it from a seperate source and found that the fan works
    but not sure if the fan should work as soon as the cd player is turn on or it works on a heat temperature and comes on wen it gets warm ?
    can someone help wen this plz
    Engine : 2.2 Direct
    I dont know so cant help you on that.. hopefully another member knows.
    Apr 2011
    england
    hi kenp ty for ya help i will hold on to see if another member can help
    thxs again for ya help
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    I here my fan start up as soon as head unit starts up
