Thread: Fog loose - will brackets be broken?
    Oct 2011
    Essex
    Default Fog loose - will brackets be broken?
    Just a quick one as it is hammering down out side, I unintentionally assisted in culling the local rabbit community at 5am on the way to work, I checked and my fog works, and is not cracked - but it is totally loose inside the bumper.
    Do you think the mounts will be broken, and if so araldite able? I know its guess work till I remove the bumper, but I could have a new fog ready for when I do if the forum gurus reckon it might be ******ed
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    sounds like the lugs inside the bumper have broken, you will have to take off the bumper to be sure.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Agreed, sounds like one/all of the plastic lugs has gone south. Look on the bright side, it could have been a fox and they're bigger and heavier and cause more damage.
    Oct 2011
    Essex
    I thought as much.... cheers fellas.
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    You can remove the fog without taking bumper off. The panel in front of arch and bumper you can get access. Various size torx. I hit a pheasant and same thing happened. Managed to clag/glue together with some auto motive sealant adhesive. (like sikaflex) and have put it back ............working fine. The replacement were quite expensive on ebay.
    8 Post(s)
    Quote Originally Posted by andrew e View Post
    One of mine had been araldited by the previous owner, but snapped again. I tried superglue, and 4 years on the plastic mount is still holding strong.
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
