Results 1 to 10 of 11
Thread: Vectra 2.2 elite.80.000 mile major service.what items?
    Jun 2009
    Middlesex
    Default Vectra 2.2 elite.80.000 mile major service.what items?
    I need do do a major service on my 2.2. Vectra C Elite (04 reg).It did not have a major at 80,000 miles.Please can anyone help by listing all items i need to replace and items to be checked as i would like to do it myself.
    Many Thanks Dobs.
    Full Member Big Sig's Avatar
    At 80k i would consider every fluid and every filter, including gearbox if you wanted to go that far.
    West
    as above & i would also consider having the timing chain & water pump replaced too
    Jun 2009
    Middlesex
    Is there a list i can get hold of apart from the normal oil ,oil filter.air filter,pollen filter,spark plugs fuel filter etc.Does timing chain adjustment need to be checked.Chain and tensioners replaced 3 years ago.
    Quote Originally Posted by Dobs View Post
    There is one in the service book that tells you what needs doing and when.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Consider doing the Anti freeze too. It has a minimum of a 5 year service life and should have a freezing point of no less than -28c. This not only provides optimum cooling and frost protection but also this provides the best anti corrosion properties for the aluminium engine castings.
    Sep 2010
    probably the most expensive service. Just done my CDTI and now at 82k needs the timing belt doing
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    All fluids
    All filters
    All spark plugs
    11 Post(s)
    Quote Originally Posted by chewy71 View Post
    But the 2.2 petrol has a camchain, not a cambelt.
    Should only ever need changing when it starts rattling.
    Jun 2009
    Middlesex
    Does the camchain on the 2.2 direct (z22yh) every need adjustment or tension checking.Mine has now been fitted 3 years.
  1. 100.000 mile service.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 07:33
  2. 3.2 Vectra Elite 80,000/8 year service
    By tedsy in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 21:25
  3. Vectra Major Service check list?
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 16:52
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. 40,000 mile service help
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 15:35
