Thread: Gear stick
    Dec 2011
    Northern Ireland
    Default Gear stick
    Alright chaps this is my first post. Drive a Vectra life CDTI. Basically the handle of the gearstick keeps coming off. Is this a common fault and is there an easy quick inexpensive solution?
    Thanks in advance.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Do you mean the gear knob? If yes, you are not alone. I fixed mine with a healthy blob of silicon sealant and a rubber mallet; it holds the knob on securely but there's enough movement so it wouldn't take much to get it off again if I needed.
    Welcome to the site. Drop into the 'introduce yourself' forum and say hello there.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    I just put a piece of paper over stick then pushed gearknob on.
    Never come loose since
    Dec 2011
    Northern Ireland
    Yes Gubmint i did mean the knob and thanks ill have to mention the silicone sealant to my mechanic. I need to get it sorted cause its dangerous and if it comes off some day and im in the wrong place at wrong time, i dread to think what could happen. And yeah i must get round to introducing myself, Ta.
    Dec 2011
    Northern Ireland
    Quote Originally Posted by troutybrown View Post
    That has actually worked trout... so far. Ill see how it goes in next few days.
  1. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  2. gear stick
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 16:32
  3. any one got an old gear stick ?
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 11:41
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
