Thread: cdti 150 2008 auto 38k starting problems
    Regular Member StarDust2k5's Avatar
    Newport, Wales
    Default cdti 150 2008 auto 38k starting problems
    Car is as in title, over the last week the car has developed a kind of missfire when cold, the revs jump about 400 rpm for about 10 seconds and then it clears and the car runs fine. While doing it the engine is also very noisy sounding like its about to die. I'm stuck with this as its only when the car is cold.
    Anyone got any ideas what could be the cause?
    LU1
    Is this an sri by any chance? Thats totally unrelated to your question sorry
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Any fault lights at all, Are the glow plugs ok.
    Newport, Wales
    no its an elite, and no lights on the dash to suggest a problem either. i was also thinking first point of call may be changing the glow plugs but trying to keep my own opinions on the cause out of the thread to see what others think without me suggesting my own theories.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If you have a ohms meter you can test them in, if not whip them out & use a battery charger or the car battery. If you haven't done this before beware ''they do get very hot'' so don't touch them till there cool again, Give the injector connectors a wiggle when its happening its just something to try, There's a how 2 for plug/wiring replacement if required.
  1. Poor Starting CDTI 150 Auto
    By 1075 in forum Engine & Drivetrain
    Last Post: 26th January 2013, 18:06
  2. 3.0 cdti auto box problems?? Help??
    By andrew1279 in forum Engine & Drivetrain
    Last Post: 18th February 2011, 14:41
  3. Starting problems cdti 150
    By zafira in forum Diesel Engine related
    Last Post: 1st December 2010, 18:43
  4. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  5. V6 cdti starting Problems - new boy needs help
    By paul g in forum Engine & Drivetrain
    Last Post: 18th August 2008, 20:27
