Thread: stuck cd cartridge in ccrt 2008
    Feb 2011
    lisburn
    confused stuck cd cartridge in ccrt 2008
    Hi all, has anyone any idea how to get the cd cartridge out it just makes a noise but nothing happens.
    Cheers,Ian.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    If you mean you have put in a cd and its stuck then i suggest a pair of tweezers and gently pull it out. It happened in my cd30 a few times.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by iwtand View Post
    Cheers,Ian.
    Had this unit on mine, in the end it had to go as it was the most annoying stereo I've ever had in a car.
    Quote Originally Posted by Mark Evison View Post
    It's the cartridge that's jammed m8 and the CD's aren't accessible unless the cartridge is ejected.
    Feb 2011
    lisburn
    anyone any ideas how to unjam the cartridge?
    Feb 2011
    lisburn
    Feb 2011
    Selby
    Assuming it's similar to the CCR2006 (which it looks like it is), then you can get the cartridge to come out, but it'll require you to remove the whole stereo from the dashboard.
    You'll find that it's actually two single DIN units fixed together, with a single faceplate. The bottom unit is the CD changer and is actually fitted as a single DIN unit in Astras and the like. If you take the unit out, remove the faceplate, and separate the two units, you'll find you can release the clips that hold the cartridge in with a prod of a long thin screwdriver. Then see if you can work out what's jamming it and gently bend it back so it's right again.
    Usually people have problems getting the cartridge to stay in these changers, as the mechanism is very easily bent, causing it not to recognise a cartridge is inserted. Sometimes takes me a dozen or more tries to get mine to stay in
    Feb 2011
    lisburn
    Thanks rich, will give that a go
    Feb 2011
    lisburn
    Took unit apart and got cd sorted now working but now I have no illumination whatever I have disturbed any ideas
  1. cd cartridge stuck
    By iwtand in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2011, 10:15
  2. cd player cartridge stuck
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 09:37
  3. multi changer cartridge stuck!!
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 21:18
  4. Ccrt 2008
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2007, 17:37
Vauxhall ccrt 2008 cd magazine help
how to remove a stuck cd from a zafira cd30 player
removing stuck cd from zafira cd30
ccrt 2008 eject
