Thread: 1.9CDTi engine question
    Regular Member fishphone's Avatar
    May 2007
    Vehicle : Insignia Tourer
    Trim : Elite NAV
    Engine : 2.0 CDTI
    Question 1.9CDTi engine question
    I can remember reading something in the forums about a process which the engine management system runs periodically (possibly to do with removing carbon build up in the engine). There was mention about poor running and increased mpg whilst the process was running. I guess I witnessed this the other week during my daily 70 mile commute as it ran like a bag of ****!!!. Can someone explain what this is all about and point me to the posts which discussed this. I cannot remember the subject of the posts I read but I seem to remember a 3 letter abbreviation (like EGR or DPF) but may have been something else.
    My car has done 33k.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    search ''dpf regen''
    hth
    Midlands Mod Shop - NFFC.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    A regen should not make the car run badly, At a random guess check your 3rd injector wiring, failing that clean the egr and boost sensor and check the rubber pipes going to the turbo actuator
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by XPCobra View Post
    It will make the car run poorly as the fueling is changed so that exhaust gas temperatures are raised to 700C. Fuel consumption increases to maintain enough performance and clear out the DPF too. It should however cause the engine to stall or run in such a way that the car is undrivable. The car won't have the best of mpg during a regen.
    If it happened for a while then I would say all is fine. The 3rd injector loom issue would cause the car to misfire, have poor throttle response and prone to stalling. Also engine management light would also come up.
    May 2007
    Trim : Elite NAV
    Engine : 2.0 CDTI
    Thanks for your prompt replies. Have searched dpf regen and understand much better now. How does the management system decide when to do the regen, does it depend on how its driven or what?
    Thanks again
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by fishphone View Post
    Thanks again
    It determined at a set mileage and the pressure difference across the DPF. THe greater the pressure difference the more it needs a re gen - which ever situation comes first, so if it suits up quickly it will re gen more frequently.
  1. Smoking engine? 1.9cdti
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 18th April 2012, 10:05
  2. the good and bad of the 1.9cdti engine?
    By *H* in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2010, 19:12
  3. 1.9CDTI engine temperature?
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 20:46
  4. 1.9cdti engine
    By sealandroader in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 21:05
  5. 1.9CDTi Engine oil?
    By Little John in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 21:17
