Results 1 to 10 of 24
Thread: left indicator flashing fast
    Jul 2011
    belfast
    confused left indicator flashing fast
    hi,
    My left indicator is flashing really fast. I no this can be caused by a blown bulb but i have checked all the bulbs even changed the indicators ones, but the left still flashes fast.
    I think it mite be the flasher unit but i cant seem to locate it. Any help would be apprecated thanks. also i have 04 vectra
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It is not as simple as a flasher unit, unfortuneately.
    The indicators involve the Under Bonnet Fuse box, the Rear Fuse Box and Rear Electrical Control Unit, the body control unit and the low speed canbus.
    My guess is a short circuit somewhere, finding it is the problem.
    What happens if you switch the hazard lights on?
    Have you tried pulling the connector of the front and rear lights in turn and see if it changes the fault?
    Also check the side repeater by removing it, removing the bulb and checking the wiring for damage.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You forgot its all controlled by the CIM...
    It's only the left, more likely to be one of the three bulbs
    You did check the wing mounted one?
    Jul 2011
    belfast
    thanks for the reply
    yes i have checked the bulbs and replaced them. When i use the hazard lights they flash at the correct speed. i havent checked for damaged wires but i will get round to it.
    Is there any fuses that i can change or any other thinmg to change thanks
    Regular Member coldo's Avatar
    Scotland
    Sounds stupid but check it by using the indictor stalk being mored to the left (so it's just one side). Check then and see fi all three are still working... Mind your checking for the one in the head light, one int he wing and the one at the back in the light cluster.
    If they are all working then and are still fast then its pointing at a short somehwere as indicated above.
    I had this once in a corsa... the hazard works all the lights yet when I used the indicator the one in the head light would not work until I swaped it out...! Really random!
    Regular Member Bigglesfliesundone's Avatar
    Jun 2011
    Darlaston
    Long shot, but I had a Merc that did exactly this and it baffled everyone, until some wise old boy said quickly operate the hazard button five times on and off as the hazard until controls (or similar) the indicators (flasher) and this resets "things". Pretty vague I know.........
    Like I said, long shot but worth a try
    Jul 2011
    belfast
    ok here goes....
    I tried holdin the stalk all the way down didnt work
    I tried the hazard lights still didnt work. What i did find is that if i hold the stalk down with the ignition off, and turn the reds on the indicator will flash normally for 3 to 4 flashs. Then it will speed up again. Any ideas
    8 Post(s)
    Have you tried disconnecting and reconnecting the battery to see if it will reset the cars electronics?
    Make sure you have the stereo code beforehand though, seeing as it's an 04 reg.
    Scotland
    Quote Originally Posted by bigpaul08 View Post
    ok here goes....
    That is properly random....
    Ok... to me it sounds like it could be the flasher relay control thing at the fuse box could be playing up. As it would seem the next natural place to look try swaping this out for a new one.
There are currently 5 users browsing this thread. (0 members and 5 guests)
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Rear Indicator lights are white when flashing
    By akeem in forum Bodywork & Interior
    Last Post: 15th February 2013, 20:46
  3. 1.9 cdti shudder and flashing service indicator, (misfire?)
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 19:12
  4. Flashing AFL indicator
    By IanW in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2008, 20:04
  5. Fuel light flashing - how many miles left?
    By Ol!ver in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 15:04
vauxhall astra indicator flashing too fast
vectra c indicator flashing fast
corsa c indicator flashing fast
astra h indicators flashing fast
vauxhall vectra indicator relay
where is the indicator relay on vauxhall vectra 04
vectra indicator flashing fast
opel kadett indicator flicking fast
vauxhall astra h 1.9 cdti side indicators not working
vectra c indicator bulb
astra h indicator flash fast all bukbs working
astra h indicator problem
indicator light flashing quickly zafira tourer
vauxhall corsa indicator flashing fast
left indicator flashing fast but not showing
vauxhall corsa c flashing petrol light
astra h flasher relay
vauxhall vectra c led hyper flash relay
corsa c indicator flashes fast
08 vectra flasher relay location
corsa c left indicator flashing fast
vectra c indicator bulb keeps loosening
signum indicator bulb fuse
astra h indicator flashing fast
flasher unit vectra c
