Results 1 to 10 of 15
Thread: Oil catch tank mod query?
    Feb 2011
    kent
    Default Oil catch tank mod query?
    Hello all,
    Im looking to fit a catch tank to reduce the amount of oil into the manifold but cant decide wether to use a closed loop system or vent to atmosphere?? Read posts about MOT faliures??
    Also, if the oil vapour is the cause of the egr/manifold problems and the breather is finished off by sending it back through the air intake, why doesnt the air filter/MAF get covered in this sticky residue??????
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Hi I have just fitted a closed loop oil catch tank to my 2.2, I had to do it this way as by trying to put the pipework to bypass putting it back to the throttle body it did not tick over correctly.
    The way i fitted it was to take a pipe to the oil catch tank then back to the ventalation valve on top the throttle body, as the catch tank was mounted on the right side of the engine I had to turn the ventalation valve around to get the pipework fitted.
    West
    venting to atmos is an mot failure, so if you go down this route... make sure it's back standard in time for the test
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Quote Originally Posted by supersport View Post
    Hello all,
    What engine m8?
    Feb 2011
    kent
    Its a 1.9 CDTI 150.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Ive been into several mot stations & the venting system does not come into the mot.
    Feb 2011
    kent
    Doh!!!!
    Hull
    obviously because it is fed in just after the airbox not before it
    Doh!!!
    Vehicle : SRi
    Mileage : 110000
    It get's fed in at its original point, all your doing is cutting into the cam breather and fitting a tank in line.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Ive got a catch tank and it hasn't caught anything. Going to vent it it atmosphere soon
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  3. Oil catch tank
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 21:08
  4. oil catch tank
    By 22ultra in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 13:10
  5. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
