Thread: is my Cylinder Head going
    Regular Member jinkie's Avatar
    Jun 2009
    greenock
    Default is my Cylinder Head going
    hello i toped the water up in my car today and looked at the top of the oil cap and there was a small pea sized blob it was a mustard colour what should i look out for its the 1.8 ls 2003 thanks
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    I'd watch the amount of water your topping up by, u shouldn't regularly top up water at all, also I wouldn't too concerned with the 'mustard' either, ya can get that if u make a lot of short journeys as the oil isn't reaching optimal temp. U also can get a compresion test done if ur water problems persists. Hth
    Jun 2009
    greenock
    i do make a lot of short journeys thanks for your help
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just condensation mate clean the cap and take the car for a good run
    Nov 2009
    N/A
    Quote Originally Posted by disco dan View Post
    I've had mine a year and a half, and haven't touched the water at all!
    Jun 2009
    greenock
    thanks for all your help
    Jun 2009
    greenock
    Thumbs up
    north east
    take the breather pipes off and clean them out, should be one from the crank case to the rocker cover and another from the rocker cover to the air intake clean both out with some wire, push the wire through then tie a piece of rag on the end and pull it back through till its 90 % clean then spray with carb cleaner and leave to dry out.
    Jun 2009
    greenock
    thanks
  1. RE-Facing Cylinder Head
    By paulcoates in forum Engine & Drivetrain
    Last Post: 7th December 2012, 16:07
  2. Cylinder head
    By GCusdin in forum Engine & Drivetrain
    Last Post: 20th September 2012, 11:11
  3. Cylinder Head
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 15:35
  4. Cylinder Head
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 18th February 2008, 17:42
