Results 1 to 3 of 3
Thread: Help with power steering fault code C1534
    Nottinghamshire
    Default Help with power steering fault code C1534
    I have got this code after the power steering fault light came up. Could anyone help with a definition for this code and/or possible things to check?
    I could only find one other mention of this fault code here but there's no definition of the code or resolution of the problem in the thread.
    The car is a 2002 GSi with the standard power steering system (i.e. not the compact one).
    Thanks.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi James ,EPS ECU circuit malfunction,sent PM
    Nottinghamshire
    Any update for anyone who comes across this post...
    I removed the wheelarch liner and found that the power steering fluid level was low so I topped it up. I also unplugged the 3 wiring multlplugs - one of which is for the fluid level sensor - from the power steering ECU and sprayed some electrical cleaner into each before letting the excess fluid drain out and re-assembling them.
    The car has been used a few times since this was done and the power steering fault light hasn't come on yet, so fingers crossed. I'll post again if the light re-appears...
  1. Please help! Serious loss of power, EGR fault code
    By dirtydan in forum Troubleshooting
    Last Post: 23rd December 2012, 11:25
  2. Fault code with no power steering
    By GCusdin in forum Engine & Drivetrain
    Last Post: 18th November 2012, 11:30
  3. Power steering fault
    By gazspeight in forum Engine & Drivetrain
    Last Post: 15th September 2011, 20:41
  4. Power steering fault ?
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2010, 20:20
  5. C1150 Fault Code - Power steering problem
    By Steeev in forum Engine & Drivetrain
    Last Post: 12th March 2010, 13:49
c1534 opel
c1534 vectra c
opel vectra c c1534
1534 trouble code vectra
1534 trouble code vectra c in thecsteering
vectra c1534
vectra c 1534
opel signum power steering fluid code
