Results 1 to 10 of 14
Thread: New Xenon bulbs
    Sweden
    Default New Xenon bulbs
    Hi guys..
    I have a 2008 Vectra cdti 150 with original xenon headlights.. But what bulb type do they use???
    Jakob
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Are they D2S? I may be wrong...
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    Yes they are D2S
    Sweden
    Thx guys!!
    By the way, I can highly recommend the yellow 3000K's!! They work perfectly in my Renault with original xenon!! They're the best in wintertime....
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Jabbekot .... 3000K where the hell do you get them? (as ive never seen them...)
    scottish region
    I'm going for 8000k again now I have a faulty bulb nice shade of blue
    Sweden
    The rule with Xenon is, that the lower the "K" the more light on the road. Therefor (and because the car is french) I went for the 3000K
    I bought them off Fleabay... Cheap..
    http://www.youtube.com/results?searc...on+3000K&uni=3
    Sweden
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    They are D1S in the Facelifts. I found that the 5000k are spot on, they look more like the A4 S-line colour bulbs
    Regular Member astradriver's Avatar
    Dec 2011
    Slovakia
    they are D1S on facelifted models and D2S on pre-facelift vectra, following link is of great help with identifying bulb types http://am_application.osram.info/publish/index_en.html
    a word of caution. The figure in kelvins (K) 4100/4300/5000 etc.. is temperature of the light. Doesn't have anything to do with intensity. Xenon bulbs (or burners) with higher temperature (above 5000) have more blue light whereas bulbs with 4100-5000 have sort of white light. Also the higher the temperature the less light (lm) there is which is the figure to look at if you want more light. So 4300K bulbs will produce more light than 8000K say. Lot of people think if they swap for 8000K bulbs they will have load of light but oposite is the true, there might be real life application for such bulbs but I think you'll find you won't see even as much as with your current bulbs especially on wet roads. Last but not least, in parts of EU bulbs with temperature of light over 5000/6000K are illegal.
    Light temperature: http://www.mediacollege.com/lighting...emperature.gif
  1. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  2. H7 xenon bulbs
    By TKD Colin in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 00:49
  3. Xenon bulbs...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 19:42
  4. Afl Xenon Bulbs
    By kantimpalo in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2008, 18:29
  5. H7 Xenon Bulbs
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2006, 19:21
