Results 1 to 3 of 3
Thread: bulbs not working indicator light on
    Regular Member faizyan6000's Avatar
    May 2011
    high wycombe
    Vehicle : vectra 1.9 diesel
    Trim : life
    Mileage : 92000
    Default bulbs not working indicator light on
    hi my head light bulb was not working so i replaced it but the indicator light in the dashboard is still on i have checked all the bulbs and they are working fine how do i reset the system so this light in the dashboard switches off.
    vauxhall vectra cdti life 1.9 diesel 55 plate
    Jul 2011
    UK
    Year : 06
    Turn the car off take key out lock car and wait till screen goes off and unlock and start it up usely works fpr me
    11 Post(s)
    System should reset itself it no faulty bulbs are detected.
    Are you sure its the headlight though?
    Double check the brake lights, because if the upper tail/brake light fails, then the lower tail light takes over the role of tail/brake light instead.
    Easiest way to tell is that you should have 4 tail lights (2 each side) and when you put the brakes on the upper of the two lights will become brighter. If one or both lower tail lights become brighter, then you've got a brake light gone.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. indicator lights not working
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 20:56
  3. indicator bulbs?
    By Rab in forum Styling
    Last Post: 4th July 2010, 11:12
  4. Light indicator on but side lights working
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th November 2008, 15:20
