Results 1 to 10 of 28
Thread: Squeaky blower motor fixed!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Squeaky blower motor fixed!
    Well - since my bloomin drain in the bulkhead blocked last few weeks water got into the blower motor and has since started squeaking. Last week been AWFULL on all speeds.
    So yesterday I removed the blower motor unit, split the motor out from the plastic casing and re-greased the bottom (that had bad water marks) with molly grease (used for hi temp hi speed bearings to shouldnt dry again) and re-assembled.
    Result - complete silence! no squeals or cherps!!.. the main motor shaft had also dropped so a few taps with a hammer later and there was no play in the shaft anymore..
    thats saved me a few £££
    A
    ps. Happy new year all..
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    my heater sounds REALLY slow... think it would help if i did the same?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by tolly View Post
    hmm - possible.. Does it squeak?
    stockport
    Thumbs up
    Spray some WD40 over the motor through the pollen filter access,should sort any issues out with no after effects,(I know it's obvious,but take the pollen filter out first!!). FELIXX.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by felixx View Post
    My advice is not to use WD - use silicone spray instead.
    However the bearings are right at the bottom of the motor and you will be lucky if much gets there.. You alo have a slim chance of bowing your resister that sits in the ducting if it gets toooo wet...
    stockport
    Thumbs down
    Quote Originally Posted by AntSSSS View Post
    I understand what you're saying,but I spray mine on a regular basis and have never had any problems whatsoever with it.I've even taken to taping an air freshener to the filter to make sure that there is a constant fresh smell in the cabin!!!. FELIXX.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Thats all good then mate.. I would have thought will defo help prevent the dreaded squeaking.. What I mean is I dont think it will resolve it once it starts squeaking knowing where they tend to squeak from..
    Good prevention tho!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    mine has started squeaking does wd 40 work or make it worse?
    what have you used ? and works well. anyone
    Jan 2012
    Cheshire
    Hiya Felixx. Got a 55 plate FL vectra myself, just bought it actually and the squeaky motor has been bothering us a little bit too.
    Can I ask a question? How do you get to the motor? Wheres the pollen filter I need to remove? Sorry for dumb questions - just need to know where to look first
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Right hand side looking into engine bay on the back bulkhead.
    Need to lft a rubber flap up and you will see it there.
    Also a good idea whilst your in that area is to check your bulkhead drain plug which is sited just below the pollen filter. Prob full of leaves.
  1. Blower Motor?
    By steve533 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2012, 22:00
  2. Vec C Blower Motor
    Last Post: 31st December 2010, 17:24
  3. Heater blower 1,2 & 3 fixed at last
    By manimal in forum Engine & Drivetrain
    Last Post: 1st December 2010, 20:36
  4. Blower motor
    By Butler in forum Bodywork & Interior
    Last Post: 13th January 2009, 09:47
  5. That Squeaky Rattle from the Boot - Fixed!
    By phil79 in forum Bodywork & Interior
    Last Post: 22nd November 2007, 18:41
https:www.vectra-c.comforumshowthread.php153122-Squeaky-blower-motor-fixed!
blower in vectra squeaking when on
squeaky heater motor on vauxhall vectra
squeak when starting engine 19 dth
squicky fan motor in vauxhall vectra
