Results 1 to 2 of 2
Thread: Battery Failing Maybe
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Battery Failing Maybe
    Recently had the Battery checked whilst in for my service by local Vauxhall Dealer, it passed the checks and issued me with the print out.
    Heres the situation -
    I don't use the car for 24 hours, when I then start the car it seems to take a while to start whilst all the lights on the dash disappear or dim to very low.
    Although the battery was tested recently and passed could there still be an issue with the initial cranking amps of the battery.
    Thanks in advance.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Sounds more like you have a short circuit or its a bad earth connection .
    Was the battery tested under looad this would show up whether or not you have a s c or bad earth connection . failing that your alternator is on its way out
    and still loving it
  1. possible alternater failing?
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 18:32
  2. Replies: 5
    Last Post: 7th October 2011, 16:58
  3. Possible Oil Pump failing???
    By dtmwelburn in forum Engine & Drivetrain
    Last Post: 11th September 2011, 19:52
  4. Wipers failing.
    By izonoky in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 23:08
  5. cdr2005 failing
    By tarandy in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2006, 20:13
