Thread: Z30DT DPF Re-Gen
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    Default Z30DT DPF Re-Gen
    Does anyone else notice a slight vibration from extra revs once theDPF kicks in? Also I have noticed that my mileage on the range goes down by about 40/50 miles in a matter of seconds is this the norm? Oh and the temperature shoots up too????-
    I have the Z30DT Auto.
    Full Member Big Sig's Avatar
    Yes pretty normal. It uses diesel to burn the soot in the dpf.
    Regular Member ph67's Avatar
    Northamptonshire
    Yep, all sound normal, I get the following on a DPF re-gen on my Z30DT:
    1. Fuel consumption goes from 0.1 Gal/Hr at tickover to 0.9 or 1.0 gal/hr.
    2. Water Temperature goes up from 85 to about 88/89
    3. Engine sounds a little bit coarser and has increased vibration
    4. Throttle response is different, seems a bit more laggy on acceleration
    5. Range will drop by 40 - 60 miles during the re-gen, though largely most of that will come back after some normal driving after the re-gen - I don't think it actually uses that amount of fuel to do the re-gen.
    Apr 2011
    EMEC #3
    Yeah that sounds about right however mine seems more responsive and has a nice growl to it when I pull off! wish it sounded like it all the time.
  1. Z30DT EGR Removal - How do I do this?
    By iani in forum Y & Z30DT Specific
    Last Post: 4th July 2012, 16:56
  2. z30dt egr valve
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 19:10
  3. can the egr be deleted Z30DT
    By rayvo-gsi in forum Y & Z30DT Specific
    Last Post: 26th April 2012, 12:21
  4. 3.0 v6 z30dt DPF problems?
    By zerocool in forum Y & Z30DT Specific
    Last Post: 11th December 2011, 01:17
https:www.vectra-c.comforumshowthread.php153101-Z30DT-DPF-Re-Gen
