Thread: Wheel well filling with water?
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Wheel well filling with water?
    My spare wheel well keeps filling with water, only a small covering but its more than should be in there, is this simply condensation that has run down the rear window and collected here?
    How can i stop it?
    Check the condition of the roof aerial seal
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I put sealant round my aerial base yet to check if it's worked.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    What seleant gaz?? Bathroom sealeant or what? Have you now just removed all the rubber that was corroded?
    Nov 2010
    UK
    cheers, is it easy enough to pop the aerial out? i understand the roof lining will have to be dropped but is it much more difficult than that?
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    there are so many more things it could be so i would start with the easiest first mucker ,
    mine was sealent cracked on top left inner boot where it was welded at the factory,or could be the gutter clips broke,could be glass seal gone but it always drips on the inner compartments left or right you just got to get a hose and work upwards muck good news is though they all do-able so good luck
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Jow20 View Post
    Just use some black all purpose sealant can get it from Halfords for about a fiver
    Sep 2011
    Newport
    I had the same problem not so long ago, all fixed now.
    Mine turned out being as simple as the rear lights were not tight, the water was running down the back of the light, down the cables and into the spare wheel area. (Got a Signum, so could be slightly different to the Vec's)
    Just make sure that the seal on the back of the light (Between the light and the actual car is sealing properly.
    Hope this helps
    East Midlands
    Quote Originally Posted by Thom View Post
    How can i stop it?
    Have a look at this thread
  1. Water in spare wheel well!
    By andyrad29 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 20:22
  2. water in spare wheel well
    By surfage in forum Vectra C / Signum Troubleshooting
    Last Post: 15th October 2012, 12:13
  3. Passenger footwell filling up with rain water
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 17:01
  4. Signum - Water In Spare Wheel Well
    By Signatum in forum Bodywork & Interior
    Last Post: 23rd October 2008, 07:22
  5. Water in spare wheel well
    By Sam in forum Bodywork & Interior
    Last Post: 25th July 2007, 17:09
why does my vectra boot keep filling with water were my spare wheel is
