Results 1 to 10 of 19
Thread: P0105 - damn !!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default P0105 - damn !!!
    Y30DT but problem common to other models - P0105.
    Just taken the boost sensor out to clean it. Looked OK so didn't bother cleaning it. Refitted it and now getting P0105.
    Can't clear the fault so what the hell's gone wrong?
    Something simple always turns into a nightmare for me on this car .
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it in properly? And connected properly aswel?
    Non of the vac pipes are loose are they? Double check all the jubilee clips
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Just had everything off again Critch and all is as it should be.
    This is a real pain as I need the car later .
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    If its all connected properly. Disconnect batt for 20 mins should reset everything
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    P0105 is the barometric pressure sensor . or manifold pressure sensor malfunction . not to sure on where this sensor is on a 3.0 but on 2.0 dti its fitted behind the maf .
    earlier this year i had a problem with this and all the problem was the elec connection,s needed a squirt of wd40 and a clean with some emery cloth and all was fine after
    and still loving it
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Critch View Post
    Doing it as we speak .
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by bobssignum View Post
    Thanks Bob, will give the connectors a clean whilst the battery's off.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    If you have a laptop and interface, checking the voltage across the Barometric sensor will show if it has failed.
    0v or 5V (not sure which) is connector loose,
    1.6v = Sensor Fail, 4.0V = sensor pass,
    Barometric pressure will probably be around 100Kpa in either case if connected.
    I do wonder if pulling of the connections for the boost sensor affects/blows the Barometric Sensor.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by TonyP2020 View Post
    Is this the same as using laptop and diagnostics software?
    Many others seem to have disconnected their boost solenoid with little or no problems but I was also thinking something could have blown.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Critch & Bob - disconnected battery for an hour and sprayed connectors with WD40. Still got the problem.
    Update - a summary of what happens......
    Turn ignition on, clear code, start engine, ticks over normal at 700rpm for 2 seconds then hits 1000rpm. EML and spanner light on at this point.
    Turn iginition off, turn ignition on (don't start engine), clear code, turn ignition off. Turn ignition back on and immediately fault code P0105-03 is back again.
    If I disconnect the connector to the boost solenoid, I get the same results as above.
    Man I'm confused and worried. Why did I ever bopther to check this sensor in the first place - should have left well alone as the car was running fine. Mega .
  1. PLEASE HELP!! Error codes p0100 & p0105
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2012, 13:32
  2. Error codes p1105 and p0105
    By signum_05 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 12:58
  3. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  4. P0105 - can I still drive the car?
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 7th January 2012, 01:13
  5. P1105 and P0105 Help?
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 00:30
