Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: water in boot
    Feb 2011
    cheshire
    Default water in boot
    when i did tyre pressures on saturday, i also checked the spare tyre,but noticed some water in the spare wheel well,so emptied the boot to mop it up,all the plastic bungs in well were full of water,cant find out where it`s coming from yet,but it was coming from offside by the rear light,i have had a look on the (how 2s) and maybe thinking of replacing the aerial base,but it dont look to bad really,any ideas,info,greatly appreciated. vectra c 1.8 hatch,thanks
    Regular Member farley2708's Avatar
    antrim n.ireland
    check the rear light clusters,rear quarter windows,aerial base (i had the same problem with water in wheel well) roof rails,the insert bits that run down the side of the roof,they are attached to a plastic clip,this clip is rivited to the roof during manufactor,on the rivit there is a foam washer,during time this can perish
    will PM you the part number later of the clip,only a few pence in vx dealers
    East Midlands
    Common problem this mate,i have the very same.
    Heres what i have done up to now.
    1/Replaced the aerial base gasket with THIS ,sealed with silicone sealant after fitting, i know its for a vw but it does fit.
    2/Removed the roof rack rail and silicone sealed around the last rivet near the clip which holds the trim in place.
    Have a look at the pics and i'll demonstrate where you need too seal up.
    The text is a bit small on this pic,this is where the water gets into the boot it wells in the area i have circled mainly when you open the boot,it then drips down by gravity or when the car is being driven and runs down into the gap where the arrows are pointing.
    You can see here where the water mark shows its been running in from here.
    You can see in this pic the arrears where i have sealed.
    I have also sealed across the entire length of the bottom rubber seal just in case in runs down into the boot behind the back of the seal its self.
    Now i'm keeping my fingers crossed here that iv'e cured the damn thing,i sealed all this yesterday morning and went for a drive yesterday afternoon in Derby and also on the M1,I have opened the boot this morning and it is bone dry,but as said not entirely convinced just yet.
    If i were the poster i would be looking at these areas first.
    And finally good luck.
    Feb 2011
    cheshire
    thanks for the replies, i will have another look at it later
    Regular Member coylo5's Avatar
    May 2007
    n.ireland
    did it do the trick? just found water in my boot too.
    Feb 2011
    cheshire
    the job was a bit of a pain to do,but me and my lad sorted it,took aerial base of the car,put a load of silicon under it,put it back on, wiped the mess off the roof, sorted.
    Jun 2011
    Kent
    Mask around aerial base and then apply some seek & seal, it's clear & not too messy.
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    Mine leaking aswell, it runs down the nearside rear quater pannel, and lands in front of the fuse box, the ariel base is my next port of call. I changed it a couple of years ago as the rubber gasket was knackered and this ones starting to crack, also i'm going to seal it with some black silicone as soon as I get chance!
    Full Member paul.sessions's Avatar
    leighton buzzard
    mine was the aerial base corroded.
    Feb 2012
    Sheffield
    I have a boot full of water too! I think its running down the off side pillar tho as there are water droplets in the cubby hole where you can store stuff? the arieal base seal is perished too but is it normally the LH pillar when its getting in throught the arieal?
  1. still water in boot
    By cutchy in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2012, 20:56
  2. Water in Boot
    By bigmac in forum Bodywork & Interior
    Last Post: 9th April 2009, 20:12
  3. water in the boot
    By billyyoung in forum Bodywork & Interior
    Last Post: 9th January 2008, 18:58
  4. Water in the BOOT!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 09:06
  5. Water in boot - Please help
    By sanasana in forum Bodywork & Interior
    Last Post: 2nd April 2006, 10:27
vauxhall vectra c water leak in boot
vauxhall vectra c water in boot
rooftop aerial vectra b hatchback rubber seal washers
vectra c roof rails remove
vother in peugeot 307
