Results 1 to 3 of 3
Thread: loose rear wiper arm
    newport
    Default loose rear wiper arm
    basically, although the actual fixing is solid, i half about an 1" and a half of movement at the end of the wiper, it wipes the screen fine, but comes to rest slightly on the paintwork of the boot under the window.
    i know i can undo the nut and move it upwards a bit, but would rather fix the problem that disguise it.
    is this a common problem, is there an easy fix, or would the whole motor mechanism need changing?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    As u say mate I unbolted mine and moved it up it's perfect now mate
    Feb 2011
    Selby
    Mine's like that too - the bit fixed to the motor shaft it solid, but the arm on the other side of the joint is loose. The joint is just plastic, so I suspect it's simply a case of the plastic wearing and allowing sideways movement.
    Probably the only real fix is a new arm. But you might be able to recondition the joint somehow so it's got less sideways movement.
  1. Loose Wiper stalk
    By Jebus in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2012, 21:41
  2. Front Wiper loose?! how? why?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 19:21
  3. Loose rear end...WHY?
    By BlueRob in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2008, 19:15
  4. Loose rear end...WHY?
    Last Post: 29th July 2008, 18:33
  5. loose rear end?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2007, 12:09
