Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Starting problems update
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Starting problems update
    Following on from a recent thread,i was having starting issues(when the engine is cold)so on thursday i left my car overnight at my local vauxhall dealers so they could do a diagnostics test the next morning when the engine was cold.The next afternoon i got a call to say my car was ready for collection,no fault codes where found,the glowplug heating system was fine,as was the injector seals,leak off pipes and the coolant temp sensor was ok.The mechanic gave my injector seals a tighten as he thought they were a slight bit slack and i was told to take my car home and see if it made any difference but the car is still hard to start when cold.
    Has anyone got any ideas on what else i should check as i might take it back to the stealers on tuesday morning for a 2nd look??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    How long is the glow plug light staying on for?
    Think there is a software update for the ECU for this issue?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the glowplug relay is faulty.
    Derry
    Thanks for the replies guys,the coil light illuminates for approx 3-5secs,the guy at the dealers said that the relay was fine,would the tech 2 not show up a relay fault,also can you explain what you mean about a software update?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by VECTRA HEAD View Post
    The software on the car's ECU tells the glow plugs how long to stay on for, dependant on the temperature. The new update from Vauxhall changes this, basically, telling the glow plugs to stay on a little longer. There's an old post on here about it, I'll try and locate it.
    Try cycling the glowplugs 5 times - turn ingition on, wait for glow plug light to go off, turn ignition off, then on, wait for glow plug light to go off..... Do this 5 times, then start the car.
    HTH
    EDIT >> http://www.vectra-c.com/forum/showthread.php?t=123211 - POSTS 3,4,5,6
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    stick a new battery in her it will make a while difference
    Derry
    i`ll give it a try in the morning Tony,Peadar i was thinking about the battery also,my m8 works in a motor factors so i might get him to lend me a new battery for a day or two to try it out,if it doesnt help i`ll just return the battery to him!!lol
    Derry
    Well i`ve just been out and tried the car like you said Tony as the car hasnt been started all day,ie turn ignition on and off 5 times before starting and it`s still struggling to start??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Did you wait for the glow plug light to go out before turning ignition off then on, each time?
    ---Sent from my iPhone 4 using Tapatalk
    Derry
    I did Tony,the coil light was staying on for approx 4-6 secs on each turn of the ignition before i attempted to start the car
  1. starting problems
    By beat275 in forum Engine & Drivetrain
    Last Post: 19th February 2013, 19:41
  2. 2.0 DTI Starting problems
    By vx sri in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 22:36
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. Starting problems
    By Narutodono in forum Engine & Drivetrain
    Last Post: 6th January 2011, 22:56
  5. Update on my vectra not starting
    By mathewjcooper in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 07:34
