Results 1 to 10 of 13
Thread: Help!bonnet wont open!
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default Help!bonnet wont open!
    Hi folks!ive got the dreaded stuck bonnet and was looking at previous threads on here on how to release it!car is a 2.0 dti 52 plate.no matter how hard i pull the cable with pliers it doesnt release!i have broken my grille to find i can push the black plastic paddle with a steel rod attached and it doesnt release still.does anyone know(again)!!how to release the bonnet as its been really difficult do far?thanks
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    We're abouts are you pulling on the cable?
    Can you get into the mechanism it's self with a long flat blade screwdriver?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Get someone to push down and lift the bonnet repeatedly as you pull the cable. This should hopefully free it.
    Sounds like the bonnet is not pushing up on it's rubber stops, thus not leaving the catch disengaged after you've pulled the cable. Had this on my old Vec B, Once the bonnet is up, there is 2 rubber bumpstops on the bonnet that can be adjusted by unscrewing them from their mount to increase the lift when the bonnet is down.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Im just pulling on cable what is under the drivers footwell.i can lift the bonnet slightly but there aint much play on the bonnet when i push down.so if i get someone to lift the bonnet and press the bonnet whilst i pull the cable with pliers?when i lift the black paddle with the rod as i say nowt happens and its hard to see anything up there.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    To be honest jyst been out to the car again with an accomplise and pulling the cable does nothing at all!its like its already under tension.i have removed sum plastic and can see the spring and small catch but not enough room.if i give the spring a wallop will that do anytjing guys or can i get it another way like underneath and behind the radiator?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Anyone help???
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Im at Cramlington I dont think peterlee is to far away if you fancy popping over tomorrow. I can have a look. No promises though
    send me a PM if you want.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Thanks mate but im at work all week now.will just try again on the daylight but not confident!do u think if i get a large screwdriver up into the spring and give it a hammer it will work?
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Anyone????
    WGAF#5
    Sounds like the cable has slackened so it has come adrift at both ends hence why the paddle and the release do not work
    If you look through the lh slats in the bonnet grille up to the center of under the bonnet you'll see the large pin, directly behind that is the metal loop/eye that the cable locates into. It'll be about an inch away from the end of the cable.
    Try and get your hand in there and get someone to bounce on the front of the bonnet whilst you pull the eye with your fingers towards the passenger side until it pops.
  1. Bonnet wont open
    By hairymark in forum Bodywork & Interior
    Last Post: 20th December 2012, 03:10
  2. Bonnet wont open on 1.9 CDTI facelift
    By ph983793 in forum Bodywork & Interior
    Last Post: 6th November 2012, 01:00
  3. Bonnet wont open
    By boodoo warrior in forum Bodywork & Interior
    Last Post: 14th August 2011, 14:55
  4. Bonnet wont open
    By Apone in forum Bodywork & Interior
    Last Post: 17th September 2009, 00:03
  5. Bonnet wont open
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2006, 13:30
