Results 1 to 2 of 2
Thread: Bulb Failure warning
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Default Bulb Failure warning
    Not quite what you would expect from the title of the thread,
    Originally I had a headlight warning (low beam) I think it said I fixed this replacing the blown bulb then it changed to Breaklight warning on the dash for a while until I discovered the sidelight takes over when the breaklight bulb blows so I replaced that but still had the warning then discovered the other side had gone aswell, I then discovered on the nearside rear there is a bulb that has no function (im guessing its a foglight for a LHD vectra but not used?) anyways I used that to replace the blown breaklight this then fixed the Breaklight warning. Now I have no warnings at all I can even now see the radio station, the only problem is my other headlight bulb has blown but no warning, I also have an ! when ever I start the car then it goes out immediatly.
    Do I have a problem or should I just change the bulb and not worry about the warning for it not working?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    change the bulb and leave it alone thats what i would do or put a hid kit in
  1. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  2. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  3. bulb failure warning
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 11:03
  4. Bulb failure warning for factory Xenons?
    By stevedee3 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2006, 12:53
