Thread: Blower trouble.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Default Blower trouble.
    Hi my blower only works on 2 & 3 with the dial and 4 with the button, 0 & 1 setting is the same no air flow but slight noise from motor area. I have taken out heat resitor and i think its working as it gets hot, if i unplug it the fan only works on 4 with the button. I have also checked the relay (the blue one) if i take this out only works on 4 with the button. and i have taken out the controls and cleaned the contacts with cleaner still no joy, i have two spare 240c thermal fuses if i need to change it but like i said it gets hot so im guessing it still working. I have looked through old posts but they all seem to have different simtoms, any help is very greatful.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    wonder if ya dials are faulty mate ie the speed selector
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Thanks for reply,i dont think so but i shall go and have a play and see.
    That's what happened to mine, I didn't notice setting 1 had failed and eventually 2 failed
    First, check the pollen filter is not blocked
    Whilst you are there, clean the inside edge and remove any debris
    If a new pollen filter is required, recheck
    If setting 1 is still not working replace the resistor pack
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Have had a play with the dial took it apart cleaned all brass conectors and pins still no joy, took it apart down to the brass pick up part with 4 lugs/flaps on it they are making contact with the backing brass plate. have also turned the housing part of the dial (the back part that holds the brass selectors and white dial part) all the way round both ways still only two fan speeds. so im still stumped.
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Its not the pollen filter still quite clean and never been wet while i have owened the car (4years). its not just setting 1 i have lost it is 4 as well, thats if 4 on the dial is the same speed as pushing the window clear button?.
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Default Found the problem
    It was the main control board on the fan speed side there is two mirco switches (see photo's the black parts.) at 4 oclock and 8 oclock these little ******s turn the fan off (8 oclock switch) and full speed (4 oclock) bridged the 8 oclock switch and the fan turned off, bridged the 4 oclock switch and the fan run at full speed. Now to get a new/second hand one.
    East Midlands
    Nice one hope you you get it fixed.
  1. Blower
    By nokiaman1978 in forum Bodywork & Interior
    Last Post: 23rd April 2012, 22:43
  2. Need help with blower/fan
    By coogar in forum Bodywork & Interior
    Last Post: 31st January 2012, 16:52
  3. Motor Blower trouble, epic bodge job from previous owner!
    By user999999 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 10:18
  4. blower
    By bakery in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 15:18
  5. Not hot air thru the blower!
    By jimmytarnat in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:15
