Thread: 3.2 V6 Auto. Spasmodic shudder into top gear.
    Mandurah, Western Australia
    confused 3.2 V6 Auto. Spasmodic shudder into top gear.
    Hi All
    Just drove the Vectra across Australia. East to West. Car performed magnificently.
    Car running very well, but the auto occasionally shudders going into top gear. Under light acceleration. Only top gear - all other changes are smooth. Under power - no shudder. And it is only sometimes.
    Any ideas? All and any advice will be greatly appreciated.
    BTW, if anyone wants to know how fast the Veccy will go across the Nullabor Plain, PM me.
    Happy New Year All!
    CDXI
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    When was the last service on the gear box mate go one tell us how fast lol
    Been serviced every 10,000 km. The speed limit on Australian highways is 110 kph.
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I would say probably what paul is thinking aswel get an oil and filter change on the box first.
    And see if that helps
    Thanks guys.
    South east
    Could be the dreaded gearbox-oil-mixing-with-coolant issue. If you have the oil changed, have a good look at the oil that comes out to see if it's mixed with water.
    I think GM issued a recall over that, and this car went back for a mod, but I will check. Thanks. I sure hope it isn't. All the other gears are fine. It is only when it kicks down to top. Almost the same sort of little shudder as when you go over small bumps. But not all the time. Strange.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    We had a reconditioned gearbox fitted in October 2008 due to coolant contamination. It started doing what you're describing in the spring of 2011. We had the car serviced in november 2011, asked for a gearbox oil change. It's now smooth as silk The gearbox has 60kkm.
    Thanks Celes. I will get the gear oil replaced.
  1. auto gear box help anyone?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 25th September 2010, 00:30
  2. Programming the auto gear box?
    By TopRod in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 11:05
  3. Auto gear changes
    By Alansilverfox in forum Engine & Drivetrain
    Last Post: 13th June 2009, 19:56
  4. Auto gear box only 2nd & 5th pls help!!!
    By watkins1172 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:48
  5. New Auto Gear Box going a bit Crazy???
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 22:05
