Results 1 to 10 of 14
Thread: immobiliser i think?
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default immobiliser i think?
    is it fuel pump or starter that the immobiliser controls?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Turbomanrony View Post
    It effectively controls the lot these days - centre of it's attenton is probably the ECU I imagine.
    Sep 2010
    LEEDS
    but will that stop it from cranking over?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Possibly but you have mentioned in the other threar that the clutch has been replaced, so the starter motor has been removed then reconnected incorrectly?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Thatchem has to cut both fuel and ignition, the vectra has this system. A simple abs plug fault can also stop the car from cranking,(especially pre 54 plates) nothings simple these days im afraid.
    Sent from my Sony Ericsson Xperia using Tapatalk
    Nov 2011
    Dewsbury
    immobiliser definately stops it even cranking over on vecs, I recently tried a known working spare engine ECU on mine and it wouldn't even crank over (I'd forgot about the immobiliser, DOH!) put the original one back on and it fired up.
    Sep 2010
    LEEDS
    Quote Originally Posted by wacky77 View Post
    immobiliser definately stops it even cranking over on vecs, i recently tried a known working spare engine ecu on mine and it wouldn't even crank over (i'd forgot about the immobiliser, doh!) put the original one back on and it fired up.
    what model is your vectra?
    Nov 2011
    Dewsbury
    52 plate 1.8 duel fuel heap o junk.
    Sep 2010
    LEEDS
    Ye well 2 diffrnt cars really mines 05 plate cdti 150
    Nov 2011
    Dewsbury
    reading your other thread sounds like an important connector's been left off or a couple have been cross-connected when the clutch was changed
  1. immobiliser help
    By Tallywhacker in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2011, 18:04
  2. immobiliser 1.8Ls
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 14:06
  3. Immobiliser.
    By bigjoe in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2010, 17:06
  4. car immobiliser
    By mrpatterson2008 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2010, 22:27
  5. Immobiliser Question
    By stevie b in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2007, 22:03
