Thread: rear door wont open
    Jul 2011
    Twickenham
    Default rear door wont open
    hi guys,my rear door will not open on my signum,sometimes on second click it realeses but u cant open it any ideas ?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    New lock
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds like the lock is jammed.
    South east
    Quote Originally Posted by kenp View Post
    New lock
    No, new exterior boot handle. The handle has a ball bearing under it that triggers a microswitch, the ball bearing gets gummed up and won't move. Buy a new handle from Vx, about £17, it has a newer design that doesn't have the ball bearing.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by Rebellion View Post
    It can be cleaned up with WD40 and made to work again. Remove the rubber cover then just clean it up with WD40.
    The rubber cover is a bit of a faff on to get back in place with the use of a small flat blade screw driver. But it can be done as I have done mine twice.
    They generaly stick when it turns cold and damp.
    Thats if it is the boot your talking about
    Mar 2011
    North Lancashire
    Default Signum tailgate won't unlock.
    Just had the tailgate refuse to unlock on the 'zapper'. All other doors working OK. Big problem is - how do I unlock it manually to get at the lock bits and pieces. (Managed to get dogs out thro' back door - phew !!)
    South east
    Look for a manual unlock mechanism on the inside of the tailgate - should look like a slot for a screwdriver to go into and you turn it.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    If you are in fact referring to the "Boot/Tailgate" Andy then this may be of some use to you :-
    http://www.vectra-c.com/forum/showth...t+lock&page=2v
    http://www.vectra-c.com/forum/showthread.php?t=37099
    http://www.vectra-c.com/forum/showthread.php?t=141403
    But if you are reffering to the "Rear Door" (as posted in topic title) then I think it will mean having to get the door surround off in order to get access to the locking mechanism inside the door to try open it. Then I guess you'll have to either replace the locking mechanism unless the fault is easily identifiable/repairable
    http://www.vectra-c.com/forum/showthread.php?t=88286
    http://www.vectra-c.com/forum/showthread.php?t=117401
    Good luck getting it sorted
    Damo
    Mar 2011
    North Lancashire
    Thanks for your help, mate. My Siggy is a face-lift model ('07) and there is no sign of any lock/keyhole etc. on the inside. I seem to remember that one of the number plate lights comes into the plot - anyone any ideas on this, please.
    Quote Originally Posted by Sabreman View Post
    look at thebottom middle of the tailgate trim in the boot and there may be a rubber grommet
    if there is pop this out and the unlock mechanism is behind this
  1. Rear door wont open
    By fingers66 in forum Bodywork & Interior
    Last Post: 11th October 2011, 15:06
  2. Rear door wont open
    By Jeffb in forum Bodywork & Interior
    Last Post: 13th February 2011, 21:06
  3. door wont open
    Last Post: 10th March 2010, 20:31
  4. rear door wont open.
    By jun in forum Bodywork & Interior
    Last Post: 15th February 2009, 18:19
  5. My rear door wont open
    By rhodod in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2008, 22:34
vectra c rear door wont open
vectra c rear door wont open site:www.vectra-c.com
my opel vectra back door wont open
