Thread: Facelift 1.8 SRi Clutch
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Facelift 1.8 SRi Clutch
    My mate has this model and has an issue with the clutch when cold.Clutch seems juddery when cold but disappears when car heats up.Only had the car 4 months and car has covered 13K miles. Any advice/info would be appreciated.
    not the 1st 1.8 to have a juddery clutch.. quite common...
    he'll have to take it back in to get checked..no dual mass flywheel on these cars..just a typical 3 part clutch..hopefully it's just a defective pressure plate..
    Regular Member m20_swe's Avatar
    Oct 2006
    greenock
    might be the flywheel mines is a 1.9cdti 19k miles i was having problems with my clutch put it in to arnold clark and they said it was the flywheel what needed replaced
    but they cant get their hands on one
    nope.. you have a cdti, that has the dualmass flywheel... the petrols don't have them..
    Regular Member steve.o's Avatar
    Jun 2006
    walking in memphis
    Mines a pre-facelift 1.8 and suffers the same prob Seems to be a 1.8 thing as other members on here have had the same prob with the clutch.Did take it back to the steelers after a couple of months,they said there was nothing wrong with it,well they would wouldnt they Had the vec now for nearly two years and it still does it.My advise would be to take it back and have a rant,dont let them fob you off,get it done while still under warranty.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I've noticed that mine has started that just recently (10k) so I think I might pop back to Burnham Garage...
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    mine does this for the first couple of miles when its cold......bl00dy annoying....
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. pre-facelift 3.2 GSi clutch replacement
    By peelmeister in forum Engine & Drivetrain
    Last Post: 28th June 2011, 13:02
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  5. Retro-fitting pre-facelift passenger door switch to facelift
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 15:58
