Thread: Ccr2006 and parrot kit
    Dec 2011
    Somerset
    Default Ccr2006 and parrot kit
    Hoping some one might be able to help me. I have got a 52 vectra elegance 2.2 dti and ccr2006 radio. I have put parrot kit mk6100 in which works fine with sot lead installed. But am unable to put radio into telemute when handsfree in use. Tried they yellow mute cable from blue parrot box into all 3 options on the parrot harness and none work. I do have the cable plug behind glovebox and I am lead to believe its one of them but anyone know which? Many thanks.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    last post
    http://www.vectra-c.com/forum/showthread.php?p=871243
    you could also just get a lead to put in the vda plug that you have.. ive done that..
    Dec 2011
    Somerset
    Many thanks. That's exactly what I was after. Looked for ages but couldn't find the info. Didn't realise there were leads to go into the vda plug. If using the vda would it play music through all the car speakers? As my parrot does music over Bluetooth.
    Engine : 2.2 Direct
    Yes it does... but only on front speakers.
    Nottinghamshire
    Quote Originally Posted by kenp View Post
    And only in mono too - the telephone input on the VDA connector only supports 1 channel of audio seeing as that's all you get on a phone.
    The VDA connector is therefore fine for telephone only (this is what I used because I got a telephone-only Parrot kit) but if you want to use your Parrot kit for music you'll be best using the usual cable that connects to the wiring on the back of the stereo as this will give you stereo sound and through the back as well as the front speakers.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i had a proble like that but it was my sub wouldnt mute eveything did must bass bangin lol all soted now though
    Dec 2011
    Somerset
    Many thanks for your reply. Well wired in parrot with sot cable to radio and yellow wire to pin 4 on vda all works a treat as it should.
    Engine : 2.2 Direct
  1. CCR2006 and Parrot Kit
    By Gayno in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2010, 01:28
  2. Ccr2006
    By Elevonic in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 18:53
  3. Ccr2006
    By ROB WOODHOUSE in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2005, 21:30
