Thread: banana arms
    Jul 2011
    United Kingdom
    Default banana arms
    Hi guys just need a pointer in the right direction, i've just spent the last two hours changing rear hubs discs and pads, but after the first side was done i gave the wheel a push and a pull and there is still a wee bit of play, so when i did the pass side and got the hub off i put a bar in the hole moved it a bit and now i think its the bent arms on the top, banana arm are the cause am i right? wheres the best place to get these arms from? cheers.
    Jul 2011
    United Kingdom
    Is this what i need http://www.ebay.co.uk/itm/SIGNUM-REA...ht_2055wt_1139
    And are they the exact same thing for both sides? thanks.
    Jul 2011
    United Kingdom
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    These are a common fault on the vectra c done mine 2 month ago now th cheapest place I found them were flebay £28 the pair delivered and good quality too
    Jun 2011
    Peterborough
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    Yeap that's them
    Jul 2011
    United Kingdom
    ok cheers pal. is this whats causing the play in the wheels? i cant see that it could be anything else.
    Jun 2011
    Peterborough
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    They were what was causing the play in mine and have be fine since 9/10 times its these ars on the rear causing play and no they are not sided
  1. getting rear banana arms done.
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 16th September 2013, 15:43
  2. An apple, banana and *****
    By John Bishop in forum Comedy & Humour
    Last Post: 5th October 2012, 21:49
  3. Best place to get rear trailing arms/banana arms??
    Last Post: 14th March 2012, 09:53
  4. Ebay 'Lifetime warranty' banana arms on?
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2012, 01:37
  5. Rear Control Arms (banana)
    By phil67 in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2008, 16:21
vectra c banana arms www.vectra-c.com
