Thread: Y30DT - what's this sensor?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Y30DT - what's this sensor?
    Whilst trying to acquaint myself with the workings of the Y30DT, I came across this sensor. It's made of grey plastic, has a two pin connector and screws into the inlet manifold that goes to the rear bank of cylinders. I'm guessing it measures air temperature .
    Being curious, I took it out to have a closer look. At this point, I should have taken some pics but couldn't find the camera .
    The bit that protrudes into the manifold also appeared to be grey plastic, about 3/4" long with a domed end. It was covered in hard carbon so I cleaned it off with a fine wire brush and re-fitted it. Started the engine up and for around 5 seconds, there was a severe misfire, then all was OK.
    Do you all remember that misfire I had that I nearly cured with the drilled EGR blanking plate? Well now the misfire has totally disappeared even without the drilled blanking plate in place.
    So my curiosity has led to a big result for me as the car has never run so smooth. Might be worth the rest of you having a look to see what your sensor looks like .
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Hmmm I don't remember seeing that when I stripped mine.
    Will have to have a look at that this week.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    I think this sensor is the AITS, air intake temperature sensor....
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yeah i think its the air intake temp sensor ...........im racking my brains here but i think its under the intake system on the back ...needs to be dug out so to speak ....why you looking for it ?
    Jul 2010
    Mileage : 126,000
    Quote Originally Posted by gtr1000 View Post
    Confirming that this sensor is the " Air intake temperature sensor ",...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by omega63 View Post
    Another component ticked off the parts list. Cheers mate.
  1. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  2. Y30DT - so is this the MAP sensor?
    Last Post: 1st January 2012, 18:58
  3. Y30DT boost sensor?
    Last Post: 29th December 2011, 21:27
air intake temperature sensor vectra c
