Results 1 to 10 of 26
Thread: Y30DT - so is this the turbo actuator (boost sensor)?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Y30DT - so is this the turbo actuator (boost sensor)?
    Same sort of question, if this is the turbo actuator (boost sensor?), how d'you clean it cos it don't look that easy to get off or take apart.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    looks like it mate
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    I am sure that this actuator is for the " variable vane/impellar " on the turbo charger, i will confirm this later. Its not the " BOOST PRESSURE SENSOR "!!!!!!, the boost pressure sensor and the AITS " air intake temperature sensor are fixed in the upper inlet manifold.....
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    sorry as above should of looke closer didnt see it was on top of the turbo
    Full Member Big Sig's Avatar
    The boost sensor has "boost" printed on it and mark Taylor said where it was in another if your posts.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    This is where Mark said it was located but it ain't got "boost" on it . http://vectra-c.com/forum/showthread.php?t=152970
    Regular Member benny's Avatar
    Feb 2006
    dudley
    thats the turbo actuator / possition sensor
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    this might help
    may need to zoom in slightly. to see were the arrow is poiting.
    obviously the upper manifold is stripped from mine but will give you idea what to look for.
    can take a pic tomorrow when everything in place if need be
    Feb 2006
    dudley
    Quote Originally Posted by Critch View Post
    this might help
    what job ya doing there ? .cambelt off to >? ...
    wirral
    49 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    was in middle of strip down for head gasket change
  1. Y30DT - so is this the MAP sensor?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 1st January 2012, 18:58
  2. Y30DT boost sensor?
    Last Post: 29th December 2011, 21:27
  3. Boost control with actuator arm
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 08:24
  4. Turned boost up actuator rod 2.0t
    By vectrasri20t in forum Petrol Engine related
    Last Post: 30th January 2010, 18:19
y30dt head gasket change
y30dt turbo pressure sensor
y30dt
