Thread: Y30DT - so is this the MAP sensor?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Y30DT - so is this the MAP sensor?
    If it is, I don't how see how it could be cleaned . Two multi pin connectors and two vacuum hoses, that's all.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    thats the boost presh solonid (sp) ....if your looking for a map sensor you wont find one diesels dont have em ....they have boost preshure sensors it is located in the inlet manifold some where i think down the back its a two pin plug and it is screwed into the manifold ....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by benny View Post
    Benny I presume the difference between them is a Boost sensor measures boost and a MAP sensor measures the absolute pressure? Only wondering m8.
    Feb 2006
    dudley
    Quote Originally Posted by Gazza4 View Post
    boost sensor goes above air presh .....turbo gives above atmos presh ie boost lol
    map goes bellow air presh ........say a none turbo pertol will run bellow atmos presh with a vacume
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    So this is the boost pressure sensor as it's exactly as you describe it http://vectra-c.com/forum/showthread.php?t=152973 ??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Cheers bud.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Quote Originally Posted by gtr1000 View Post
    Confirming that this vacumn actuator / electric, is the control solenoid for the turbo waste gate control mechanism....
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Thanks for clearing this one up. One more item to tick off the "what's this part" list .
  1. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  2. Y30DT - what's this sensor?
    Last Post: 1st January 2012, 18:59
  3. Y30DT boost sensor?
    Last Post: 29th December 2011, 21:27
parts list y30dt engine
y30dt map
