Thread: Y30DT inlet manifold.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Y30DT inlet manifold.
    A curiosity question - why is my cast aluminium inlet manifiold so black and dirty/greasy?
    I'm thinking one of two things:
    1) The oil breather pipe (black plastic thingy) that goes to the inlet pipe of the turbo is dragging in oily vapour which we can't avoid (positive crankcase ventilation PCV?) or,
    2) There's an oil leak on the turbo cooling system .
    If we didn't have a breather pipe, how on earth can things be so oily in the manifold?
    Just to further confuse me, the pipe from the outlet of the turbo to the intercooler doesn't have oily walls, neither does the pipe from the intercooler to the inlet manifold . Are the walls of the inlet manifold rougher than the air pipes, thereby giving the oily vapour something to grip onto?
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    The dry black powdery film that builds up in the inlet manifold at the engine end is from the EGR valve. When the EGR valve is prompted to open by the ECU, " its command signal " the EGR valve opens and allows spent/exhaust gases to re-enter the engine via the inlet manifold. The oily slimmey black grunge found throughout the air intake system is from the pipe which vents the engine crankcase. Oil vapour droplets is passed under pressure along the pipe into the low pressure side of the turbo charger, and then leaving the turbo charger on the high pressure side. It is then deposited around the air intake system i.e intercooler and hoses and throttle valve/butterfly....
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Equally, the EGR valve should only be open whilst the engine is warming and/or on low revs
    As a result the gas passing through it is very slow, so the vapour can be attracted to the colder pipe walls
    This is also why the pipe from the turbo does not get covered in oil, even though the gas contains oil, the gas passing through it is flowing so fast
  1. Inlet Manifold
    By Quirrel in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 12:59
  2. inlet manifold
    By chay6684 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 23:24
  3. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. Inlet manifold/oil
    By the-wizard in forum Engine & Drivetrain
    Last Post: 3rd November 2009, 19:11
