Results 1 to 10 of 17
Thread: P0234 Error Code Definition
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default P0234 Error Code Definition
    hello guys
    can someone tell me for sure what the error code above means
    the full description is
    ( P0234 Boost Pressure Control Circuit Positive Deviation ( 11 ) Present )
    now is this overboost or underboost ??
    may have found the problem for the error code P0234 on my car
    its hopefully going to be the
    boost pressure control valve
    wastegate actuator
    depends on the answer for the code
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Under boost. Split pipe or actuator
    Mar 2011
    Northamptonshire
    how is it underboost Matt
    i thought positive would be overboost
    and negative underboost
    i read another thread of yours about this problem
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Me too but tiss2web at work says positive is underboost
    Mar 2011
    Northamptonshire
    Excellent
    so would that be intercooler pipes or boost pipes ?
    or
    actuator
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Basically what happens is the boost sensor cannot give an accurate reading usually because it is covered in crud . The ecu then generates an overboost fault ,causing the engine to shut down to protect itself .
    All easily cured by cleaning the boost sensor , just spray the sensor tip with carb cleaner to clear Dont scrub the sensor as its easily damaged.
    May well be worth your while cleaning the egr while your there as its rare for one to need cleaning and not the other.
    and still loving it
    Mar 2011
    Northamptonshire
    cleaned boost sensor the other day
    there was nothing on it
    thought it was going to be the boost pressure valve
    Mar 2011
    Northamptonshire
    Matt is saying it is underboost
    have checked pipes and they look ok
    think i need to remove them and check them
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    That fault is overboost
    Mar 2011
    Northamptonshire
    Matt says it is underboost
  1. P0234 Error,Remapped Signum 2.8 Turbo
    By viper8 in forum Engine & Drivetrain
    Last Post: 29th December 2011, 20:55
  2. P0234 Error code.
    By ectraz in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 20:23
  3. error code P0234 - Boost pressure control
    By duncanm in forum Engine & Drivetrain
    Last Post: 4th May 2011, 17:24
  4. Replies: 6
    Last Post: 3rd September 2009, 16:40
boost pressure control circuit positive deviation
