Results 1 to 10 of 21
Thread: 1.9cdti engine wont crank or turn over
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default 1.9cdti engine wont crank or turn over
    wonder of any 1 can help
    i have a vectra just had clutch fittted and now wont crank over or even attempt to start.
    can hear fuel pump does nothing when turning key
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Starter not connected?
    Glasgow
    Flat battery is the first thing I would guess at being the problem.
    Sep 2010
    LEEDS
    every thing is connected, iv even put a live to the starter it turns over but wont start.
    Sep 2010
    LEEDS
    battery fully charged, tried it with a booster still same.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the plug on the power steering pump isnt fitted ...it is either just on or is loose in the engine bay ...lets hope they unplugged it and didnt just drop the subframe and break the plug ...
    Sep 2010
    LEEDS
    thats a good 1 going to check it tommorw
    they did just drop the subfram,
    why would that stop it from starting?
    Nov 2011
    they'd need to drop the subframe to get the gearbox out?
    Check the crank sensor too
    Sep 2010
    LEEDS
    the whole subframe came off its much easyer that way,
    its not the cranks sensor, the engine wont turn over to fire !
    Nov 2011
    It won't fire if the crank sensor isn't connected, as the ecu wouldn't be able to determine when to provide a spark at TDC.
    Worth a check, seeing as the engine turns over when you feed the starter a live wire.
  1. turn the key and nothing!!!!!- Wont start
    By Rupster_69 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2013, 13:13
  2. please help vectra 2.2 dti wont turn over
    By deano1 in forum Engine & Drivetrain
    Last Post: 20th May 2011, 21:37
  3. z22se wont turn over HELP
    By mike060280 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 18:33
  4. HELP!! car wont turn over!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 31st March 2011, 19:08
  5. VEC-B HELP, P0335 Crank Sensor-CAR WONT START
    By Vaux-Man-G in forum General Chat
    Last Post: 26th October 2009, 23:25
1.9 cdti vectra wont connect to code reader
vauxhall vectra 07 1.9cdti wont crank
vauxhall vectra 1.9 dti engine wont crank
car wont crank over vectra c
