Thread: Injector Pipes??
    Jun 2009
    Chelmsford
    Default Injector Pipes??
    Going to replace all the injector seals, and will get new pipes too, anyone have any idea of the cost of new pipes?? Cars a 1.9cdti sri
    Jul 2010
    Londonderry Northern Ireland
    seals are 38p each and the leak off pipe on top of the injectors is either £13 or £21
    Jul 2010
    and 13cdti ones fit them, they might be the cheaper ones infact, cant remember off hand
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Why do you need to replace the pipes?
    Jun 2009
    Chelmsford
    Had the pipes on & off a few times now, so now going to change all seals, and thought id change pipes as well just to avoid any problems with leaks!
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Z19DTH Injector Pipes
    Attachment 50092
    If these are the pipes you are refering to Gov then they are about £30 each (RRP) according to "Car Parts Connexion"
    Item 1 - 93179045 - PIPE, ASSY., FUEL INJECTION, NO. ONE, FEED (No Longer Sold, Use - 93191392) - CPC link £9.95
    Item 2 - 93179044 - PIPE, ASSY., FUEL INJECTION, NO. TWO, FEED - CPC link £7.88 - £9.95
    Item 3 - 93179043 - PIPE, ASSY., FUEL INJECTION, NO. THREE, FEED - CPC link £7.25 - £7.88
    Item 4 - 93179042 - PIPE, ASSY., FUEL INJECTION, NO. FOUR, FEED - CPC link £7.80 - £9.95
    Hope that helps Gov
    Damo
  1. How do you change leak off pipes and injector seals
    By m.c.jones in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2013, 22:41
  2. Cost of new injector pipes?
    By leeky1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2011, 09:23
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Injector return pipes.
    By mally in forum Engine & Drivetrain
    Last Post: 10th September 2010, 00:20
