Results 1 to 10 of 19
Thread: Just a couple of questions from a Vec noob
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Just a couple of questions from a Vec noob
    I have a plan for my car and I've got queries on a couple of aspects:
    1. I'm wanting to fit the VXR rear skirt to my pre-facelift "C" am I right in assuming the **** end of the facelift and pre-facelift C's are identical? also with my car having the 3.2 V6 I already have twin exit exhausts, will the VXR trim go straight on top of my bumper or do I have to remove/fit anything else first?
    2. My car has ESP & TC is it possible to make the TC switchable? and is it easy(ish) to do ?
    3. I'm looking into converting my dash and switches etc to Blue L.E.D's, I've found a supplier but is this job going to be a ***** to do and how hard are the gauges to convert?
    Thanks in advance,
    Kev
    spoons
    Guest
    I will answer Number 1
    Yes the rears are identical...
    Yes the VXR Rear Bumper Valance will go straight on to what you have already...
    Another option to consider is changing your existing rear exhaust trim to the VXR one (The bit in between the twin exhausts) as it only costs around £25, but you need to get it painted and fitted also... I think it looks much better than your existing exhaust trim
    you will need to change the lower bumper skirt and the insert for VXR parts, it just clips and bonds in...yes facelift rear and pre-facelift bumpers are 'nearly' identical enough to be identical..
    if you haven't got a TC switch then it's 50/50 one will work, there is no gaurantee, and if it doesn't work then it's game over.. you can't 'make' them work.
    i don't know of anyone who has converted their dash, they don't need LED's they're MSD's..so changing them will be 'fun' to say the least..hope you've got a steady soldering hand..
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    I have read on the forum somewhere around 600 solering points...
    yep, get one wrong and it's curtains.. i wouldn't want to do it...imagine breaking a track on the board..
    Engine : Z20NET
    Quote Originally Posted by spoons View Post
    I thought it was all one item as that's what I meant , I see what you mean now though, the insert in the middle with the lines on is obviously a seperate part, and looks like I'll be leaving the L.E.D'S out, I thought it might have been like the astra G etc, old bulbs come out, new bulbs go in
    not with the CANBUS system mate, it's all gone low current now..
    to get the full VXR look, change the bumper lower as well..
    Engine : Z20NET
    So is it easy enough to attempt? and if the switch doesn't work I can always take it out and things will look "as they were"
    Engine : Z20NET
    What do you mean by that mate
    you just have to pull the blank out, the part number for the switch is in the relevant forum further down..
    if you pull the blank out, just push the switch in.. it will light up if you put the sidelights on, but unless it lights the symbol in the middle of the dash then it isn't working..
  1. Noob car pics, & a few questions !!!
    By thefibreguy in forum Styling
    Last Post: 19th May 2010, 17:40
  2. noob questions:
    By ajbird in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 18:16
  3. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  4. Couple of questions?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 11:20
  5. Ditching CDR 2005 - Noob questions
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 21:18
