Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: V6 CDTi spanner ligt on
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default V6 CDTi spanner ligt on
    Tonight on my way home from work the spanner light came on in V6 CDTi and the car lost power, now I had a look in the hand book and it states that on the 1.9CDTi to change the fuel filter as water can get into it, so was wondering if if would be the same with the V6 or could some thing be causing it?
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    You need to get the ECU read, and record the error codes and any other data recordings. Its not a good idea to guess as it could be very costly....
    Did it reset when you switched off and restarted? Mine used to drop into limp home mode every now and then but I never needed to fix it, just a restart used to do the job.
    Limavady, N.I
    Mileage : 121000
    It did go out after restarting but it happened when climbing a hill and thats the 3rd time it's done it now
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by omega63 View Post
    scanner needed to find code
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    My old alfa used to do this too, driving uphill, and under load. Turns out it was overboosting and the ecu knocks off the fuel before it causes damage. I've also seen this issue as the VNT vanes sticking due to carbon/soot build-up in the turbine housing of the turbo. Have a look through the list below first, likely to be an easy fix.
    Things to check:
    Vacuum solenoid for turbo actuator (clean it if possible)
    Vacuum pipes (check for splits/deterioration)
    EGR (clean if sooted)
    ECU codes read
    Woodbridge
    If it helps you out any, the wifes came on the other day due to the vac pipe being split, went into limp mode whilst going up a hill.
    Yet another 2005 Y30DT with this (similar) erratic fault
    We could take a guess at what it might be
    As above, have the code read whilst still active
    If the warning light is on, but not in safe mode, you should still be able to get the code read
    How many times has this happened?
    Was the engine cold / still warming or hot?
    Have the uprated SCV been fitted?
    How long have you owned the car?
    Is it covered by Network Q, warranty, or third party warranty?
    With respect to the handbook, ignore any references to the 1.9 CDTI, as the 3.0 V6 CDTI is an Isuzu engine
    Equally, there should be two pages with diagrams of the engine bay
    Limavady, N.I
    Mileage : 121000
    I don't know if the SCV has been ever changed, I've owned it now for 18 months and its not covered by any warranty. Also she is the facelift model if that makes any difference?
    Of its up hill and on boost my first port of call would be a dirty boost sensor. Mine suffered with that in those conditions. Also free to check how clean it may be. Also how old is the fuel filter? Look into that before jumping to expensive scv's.
  1. V6 CDTI EML Spanner light
    By mattsbmw in forum Engine & Drivetrain
    Last Post: 15th August 2011, 21:38
  2. 1.9 CDTi (150) with spanner light...
    By parsco in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 16:09
  3. 1.9 CDTi 150, juddering and spanner!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 19th May 2009, 15:57
  4. 1.9 CDTI (150) Spanner light
    By djr69uk in forum Engine & Drivetrain
    Last Post: 17th September 2008, 15:44
  5. Spanner Indication on 04 SRI CDTI
    By Warrenmole in forum Vectra C / Signum Troubleshooting
    Last Post: 29th June 2008, 09:17
SIGNUM V6 Y30DT
Opel Signum 3.0 saugrohr sensor
vectra 3.0 cdti pipes with sensor
y30dt scv location
v6 cdti vectra c boost sensor
