Thread: Estate Bootlid/Tailgate problem
    Dec 2011
    Donny
    Default Estate Bootlid/Tailgate problem
    Hi guys,
    I currently have the vectra estate 1.9CDTI on a 57.
    When I open the car using the keyfob instead of unlocking my doors the fob will open the tailgate instead. I have to then wait 15 secs before pressing the lock button on the keyfob and then again the open button for the doors to open.
    Secondly I cannot close the bootlid with the button on the boot, instead I have to use either the button on the keyfob or the one on the driver side door panel.
    Im well confused, can any one help........
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Do you have eltric tailgate? if yes check the switch for the button on the inside.. the wiring is probaly coroded ect.
    Dec 2011
    Donny
    it is an electric tailgate, i will have a look at the switch and see what i find
    cheers
    Dec 2011
    Donny
    I opened up the tailgate, all the wiring seems fine, i removed the switch and im stll having problems, im also having an intermittent issue with the alarm going off.
    Any suggestions?
    Engine : 2.2 Direct
    Get the codes read out...
  1. Debadging an estate bootlid
    By phil-h in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 17:40
  2. Estate tailgate problem.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:33
  3. Vectra Estate power tailgate problem
    By Snizzers in forum Bodywork & Interior
    Last Post: 3rd June 2009, 23:03
  4. Vectra C Estate Stuck Tailgate Problem solved
    By samuel in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2008, 20:44
  5. Estate tailgate
    By parapaul in forum Bodywork & Interior
    Last Post: 2nd October 2006, 19:05
