Results 1 to 10 of 25
Thread: 1.8 VVT crankshaft position sensor location?
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    confused 1.8 VVT crankshaft position sensor location?
    Alright men, got me sensor today but it wasnt what i was expecting, and therefor i have no idea where the hell to fit it. This is the correct part for sure. Part number 55555806, Anybody any the wiser here?
    Lancashire
    according to tha manual Dan the crankshaft position sensor is positioned on the front of the cylinder block below the oil filter , it says you may have to jack the car up to get at it and it also says you will need a new sealing ring , just look like you unscrew it disconnect the wiring and screw the new one back in
    Apr 2011
    Southport
    Nice one mate.
    Lancashire
    yes sorry mate i thought you meant camshaft sensor , but then i read your post again and saw you wanted crank , so thats it what i posted , thats the crankshaft sensor , it says to use correct torque setting as well not sure how important that is
    Apr 2011
    Southport
    Also, what manual you got? I could use one of them?
    Lancashire
    haynes one dan , 55 plate to 58 plate , green one , £20 from halfords , covers the vvt
    Apr 2011
    Southport
    get in, thanks for takin the time out for me.
    Apr 2011
    Southport
    From the book mark, does the part in the pic look anything like what it should?
    Apr 2011
    Southport
    Also, i was under the impresion the cam and crank sensors are at the end of the camshafts, on the right hand side near the battery. Does the haynes mention it, it is a vvt btw
    Lancashire
    for the CAMSHAFT position sensor it says its on the end of the cylinder head on the cambelt side , you have to take the cambelt top cover off to see it and 2 bolts hold it in place , the CRANKSHAFT sensor is like what i said above , its under the oil filter bolted to the block , it does not show a pic of the CRANKSHAFT sensor but it shows a pic of the CAMSHAFT sensor and it does look a little bit similier to what you have on the pic although i can only see the bit which bolts to the cylinder head , they may of given you the camshaft sensor instead of the crankshaft sensor but cant be sure , but according the manual thats were they are positioned dan
  1. crankshaft sensor location
    By jones5n in forum Engine & Drivetrain
    Last Post: 4th February 2013, 23:34
  2. crankshaft sensor location
    By thugusher in forum Engine & Drivetrain
    Last Post: 10th September 2011, 11:46
  3. 1.8 crankshaft position sensor.
    By jimmyred in forum Engine & Drivetrain
    Last Post: 17th May 2011, 06:56
  4. crankshaft sensor
    By valhalla in forum Vectra C / Signum Troubleshooting
    Last Post: 13th May 2011, 13:09
  5. Crankshaft sensor location
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 12:06
vauxhall vectra crankshaft sensor location
z18xer crank sensor location
Z18 crankshaft sensor
vectra c crankshaft position sensor
crankshaft sensor location in vvt engine
z18xer crank sensor replacment
insignia 1.8 sri exhaust camshaft position sensor
zafira crankshaft sensor location
vectra c sri 1.8 is crank sensor near starter motor
1.8 vvt exhaust camshaft sensor
2006 vauxhall vectra sri 1.8 crank position sensor
crankshaft position sensor opel astra z18xers
vectra 1.8sri cam sensor
crankshaft sensor on vauxhall vectra 20062007 vauxhall astra 1800 inlet cam sensorvauxhall vectra 1.8 2006 vvt cam sensorvectra c crankshaft sensorinsignia a20dth crank sensor locationvauxhall vectra 1.8 2006 vvt how to test cam sensorCkp sensor z18xervauxhall zafira 1.8 crankshaft sensor locationcrankshaft position sensor for opel zafira 1.8vectra c crank sensor calibrationz18xer crank sensor replacementhow to fit vectra 1.8vvt camshaft sensor
