Thread: Signum cdti 150 broken down!
    Regular Member mr-s's Avatar
    Sep 2009
    Shropshire
    Default Signum cdti 150 broken down!
    As i left for work this afternoon, i noticed the engine seemed to be spluttering slightly.
    I stopped at a set of traffic lights, and the spanner light came on briefly, before going off again, so i continued onto the motorway. All of a sudden the slight spluttering turned into fairly violent spluttering/shuddering/intermittent power loss, which was literally throwing me about in my seat. It sounded like the engine was trying to remove itself from the mounts! All of this was followed by the inevitable spanner light and spluttering 'limp home mode', at which point i was on the hard shoulder switching on the hazards.
    I phoned Green Flag, who asked me what was wrong, and when i explained it to them, they said that they would just recover the vehicle, as opposed to try and find what was wrong.
    - it ended up being taken home on a recovery truck.
    The engine now ticks over, with an intermittent spanner light, and feels really lumpy between 1-3k when revving, and shudders slightly when ticking over.
    Has anybody got any ideas, as the majority of garages around me are shut for christmas, and our first child has just been born, and without the Siggy (family car), i can't get her anywhere
    Cheers,
    Scott.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Could be a lot of things mate ideally you need the codes read.
    Fuel starvation maybe.
    But first check all the vacuum pipes. As could be a split inter cooler/ pipe.
    Sep 2009
    Shropshire
    How easy are the intercooler pipes to get to on the 150 cdti mate?
    Could this be the 3rd injector problem i wonder?
    Cheers,
    Scott.
    Glasgow
    Inlet manifold, EGR valve could be a number of things on the cdti.
    scottish region
    Sounds egr related mate
    Admin plasma's Avatar
    On the Forum
    214 Post(s)
    Engine : 150
    Mileage : 74000
    easy way to check if its injector no3 related, leave engine running, pop engine cover off and move the cable near the plug about, listen to see if it starts running correctly
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Sep 2009
    Shropshire
    Thanks for the replies
    Would an EGR fault cause it to run that badly?
    Cheers,
    Scott.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    When they stick part open it can make it run like a bag of spanners, get a hammer & gently tap the METAL part of the egr with the engine running, if it has stuck it may free temporarily to give you some idea, You need the codes read really. If it is the egr follow the 'how 2' for removal & cleaning.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Third injector, by the sounds of it
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    check your injectors first before anything !
  1. Heads up Irmscher signum being broken
    By bobssignum in forum Styling
    Last Post: 3rd December 2011, 10:12
  2. Signum - Front Arm Rest broken
    By moneypit in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2011, 12:02
  3. Turbo Broken - 3.0 CDTI SRI
    By pomaikai in forum Engine & Drivetrain
    Last Post: 15th October 2008, 08:20
  4. 3.0V6 CDti broken cambelt
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2008, 20:38
