Results 1 to 10 of 13
Thread: electric tailgate opening when car unlocked
    Sep 2009
    Aylesbury
    Default electric tailgate opening when car unlocked
    Hi All
    I have a 56 plate vectra estate with a electric tailgate..
    I keep getting a intermittent fault (happens for a week or so at a time) where I press the button on the fob to unlock the car the electric tailgate opens, Secondly the buttons on the tailgate to open and close the tailgate also stop working..
    Any ideas?
    Steve
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Probaly a fault in the switch at the inside of the tailgate.. theres getting water in the switch.. replace switch and clean the plug for rust and other stuff, and when working againg fill it with silicone or other water reisitant stuff.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Mine went through a stage of opening when I turned off the engine. All seems ok now though.
    Sep 2009
    Aylesbury
    Connected a opcom to the car today and found a error code
    B1542 - Trunk Release Switch Stuck
    So set about removing the switch/button on the tailgate, Took the interior panel of the tailgate and disconnected the cable from the switch, The button to close the tailgate started working again and the tailgate did not open by itself when the car was unlocked... thus i then knew that it was the switch.
    Dismantled the switch and used a mutli-meter to check the micro-switch, all was working correctly, so looked at the rest of it and found that the metal plate that pushes against the switch was getting stuck and thus kepping the micro-switch pressed... cleaned it up and re-assembled everything and all now seems to be working correctly..
    Would have cost me £££ if i'd taken it to a vauxhall garage..
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    good work batman!
    Oct 2011
    Essex
    GGRRRRR..... my next job when it stops raining here....
    Regular Member Mopar Man's Avatar
    herts
    Well done Dreams. I have the problem of the tailgate not shutting sometimes
    Engine : 2.2 Direct
    Mopar Man thats probaly the closing swith and water to
    Oct 2011
    Essex
    I know how I did mine. Poxy CATS!
    If those FFFF****ING CATS didn't keep using my shed pent roof as a scratch pad, the felt would not have torn@blown off, so I wouldn't have loaded a roll of roofing felt in the back (of the estate) and got tar marks on the rear carpet panel. Then I need not have scrubbed the tailgate carpet and got the switch wet. And its still raining!!!!
    I might use empty a 30 second burst of solvent cleaner in it
    herts
    Quote Originally Posted by kenp View Post
    Water everywhere at the moment
  1. Electric sunroof not opening
    By Sigmacca in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2014, 01:31
  2. Electric tailgate opens itself
    By lastyboy in forum Bodywork & Interior
    Last Post: 10th November 2013, 19:42
  3. Micro Switch - electronic opening tailgate
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 00:26
  4. Rear Tailgate not Opening on vectra estate
    By si_sri in forum Bodywork & Interior
    Last Post: 28th November 2009, 21:06
  5. Estate Tailgate not opening
    By Ewormaharg in forum Vectra C / Signum Troubleshooting
    Last Post: 18th October 2006, 19:51
vauxhall b1542
