Thread: Sneak Peek... Where to earth?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Smile Sneak Peek... Where to earth?
    Been working on my car this week, Santa got me a Haynes manual for my Vec, so i've been looking for allsorts to do
    Currently have the boot in bits to pop in an Amp and wiring for a small sub
    Where do you guys use for an earthing point in the boot?
    I've got the O/S interor panel off to mount an amp and the only location i can find near enough is the rear right seatbelt mount for the spool mech. Would that be suitable?
    Spent most of the day with the soldering iron wiring up a quick-connect point for the sub itself so that i can easily remove it if necessary without unscrewing it all
    Few pics
    Pic 1&2: Panel trim with amp mounted
    Pic 3: Holes drilled for power, audio in, and sub-out (looks neater than having them hang out the 3 pre-cut vent holes)
    Pic 4: Quick-Connect port
    Pic 5: Non-obstructive mounting of the amp (having realised the panel sits on the wheel-arch, wanted somethign that wasn't going to damage the arch)
    Regular Member benny's Avatar
    Feb 2006
    dudley
    back pannel trim when removed there are loads a earth lugs under there but there the small type ...me i would run a wire back to the battery ....
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    I just scrapped the paint away from the boot and drilled hole and screwed earth into that. No problems so far.
    Remember to keep the earth cable sort though.
    Nov 2011
    All in. Used the earth point under the O/S rear light cluster.
    Working and looks a treat all tidied up
    Nov 2011
    Few more pics, forgot to take a pic of the final result,, will get one tomorrow .
    Ran the 12v Live down the passenger side, and RCA + remote down the driver side.
    Pic1 is panel pre-fit, was getting the wiring through to the amp and ensuring the cables didn't rub on the bodywork.
    Pic2, power cable through into rear quarter void waiting for RCA audio feed fitment
    Pic3, RCA feed to run down driver side, relatively easy job
  1. Replies: 24
    Last Post: 3rd June 2012, 21:36
  2. The snowies are on!! take a peek
    By peelmeister in forum Styling
    Last Post: 15th August 2011, 16:34
  3. Sneaky peek of the new wheels....
    By John LE in forum Styling
    Last Post: 15th February 2011, 00:13
  4. Peek-a-boo !!
    By thefibreguy in forum Handling & Braking
    Last Post: 25th July 2010, 11:54
  5. Lots of items for sale , have a peek !
    By deanos in forum General items for sale
    Last Post: 2nd August 2008, 19:12
