Thread: 3.2 gsi knocking noise from the engine bay
    Apr 2009
    stockton-on-tees
    Default 3.2 gsi knocking noise from the engine bay
    I noticed it knocking about 6 months ago so I decided to change the cam belt and tensioners the noise persisted so I then changed the water pump and it's still there it can only be heard on tick over and is not always there it's loud enough to be heard at the traffic lights I've read another thread on this but there was never an answer posted
    newport
    would it be the aux belt tensioner? read about problems on these on the vec b
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it a knock or a rattle?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Top end? Sticky hydraulic tappet/valve?
    Apr 2009
    stockton-on-tees
    Aux tensioner feels alright and I'd have to check the tappets and valves I think it's more of a rattle but everyone describes these noises differently I'm thinking the worst either big ends or fly wheel
    Full Member Big Sig's Avatar
    If its the flywheel then the noise will change when you depress and release the clutch pedal.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Big end is is usually a deep nock/ rumble
    And can be heard under load aswel.
    Is a possibilitie of being main bearings.
    Can you run the engine briefly with aux belt off and see if eliminates the noise
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Big ends don,t rattle, they RAP!!!/KNOCK!!!, LOUDLY when you rev the engine up. In severe cases the ECU/Engine management will back the ignition timing right off " thinking it is fuel detonation " and put the EML on....
    Jul 2010
    Mileage : 126,000
    With " Big end & Main bearing failure " there would be issues with LOW OIL pressure, the oil pressure warning light may " flicker " whilst the engine is idling, or at worst come on and stay on!!!
  1. Knocking noise.
    By burbling1 in forum Suspension, Wheels & Brakes
    Last Post: 27th October 2012, 11:27
  2. knocking noise
    By jinkie in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 16:14
  3. Knocking noise
    By welshboy in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2011, 12:28
  4. help with me knocking noise please....
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2010, 21:00
  5. Knocking noise
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2006, 11:47
vectra c gsi knocking noise
