Thread: Cigarette Lighter
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Cigarette Lighter
    Whats the difference between a standard 12v cigarette lighter and the non lighter type accesory port wich i have, are they not both 12v ?
    would the connections still be the same if i was to buy a standard across the range cigarette lighter housing, i have tried to put an actual lighter in but it blows the fuses. thanks
    Last edited by The Gas Man; 29th December 2011 at 21:35. Reason: forgot to say thanks haha
    11 Post(s)
    The hole in the accessory socket is slightly smaller to prevent you inserting a ciggy lighter adapter.
    The voltage and connections are the same though. Centre tap is +ve, and the other edge is -ve.
    Feb 2006
    north east
    thanks for that Dave ,somehow ive managed to put a ciggy lighter straight in and it blew the fuse , however if i put in any chargeble unit it works fine , the one i have has got a flap over it so i presume its an accesory port
    11 Post(s)
    Yep, flap is an accessory socket, and not meant for ciggy lighters.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Ciggy lighter port has a clip in the bottom to hold the centre of the lighter element while it heats and releases it when it's done.
    Accessory socket has no clip in the bottom and purely for things like sat-nav's, in-car chargers for phones etc
    Full Member Big Sig's Avatar
    Are the cables the same size to allow for the larger current from a lighter? Hence the fuse size that keeps blowing to protect the cables?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It will be the same size cable mate
    Feb 2011
    Selby
    Both the same 10A supply. The only difference is the shape of the socket so it allows the cig lighter to disconnect when hot. Accessory plugs are designed to fit cig lighter sockets, but cig lighters won't work in accessory sockets (and as you found - can blow the fuse if you do manage to get one to go in)
    My 1991 Pajero has both cig lighter and accessory sockets on the centre console (acc sockets have hinged covers, cig lighter has lighter unit), so it's not a new thing having two very similar but slightly different sockets.
    My Vectra has a cig lighter, but it's just rattling around in the glove box, as I'm using the socket as an accessory socket for charging my phone etc.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I converted my cigarette lighter (pre-face so it had the ciggy lighter not accessory socket) into the accessory socket, takes a bit of fiddling and farting around to get it all to fit, but basically I have the accessory socket top with the original cigarette lighter and cigarette lighter lighting surround fitted into it.
    Feb 2006
    north east
    Thanks for the replys , whats that cable running Ian,
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. No Cigarette Lighter
    By kingy999 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2010, 21:46
  3. Cigarette Lighter
    By BJRM7241 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 16:28
  4. cigarette lighter
    By PYNE999 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 11:28
vectra c cigarette lighter wont work
