Results 1 to 10 of 14
Thread: Z22YH EGR Mod??
    Dec 2011
    Midlands
    Default Z22YH EGR Mod??
    Hi,
    Sorry for posting something that i am sure has been done to death, but i cant find enough to answer my questions, so here goes....
    I am giving my 2005 2.2 Direct Sri a service and thought i would quickly whip off the throttle body to give it a clean. I was expecting a bit of gunk on there but i was surprised at just how much there was. I have cleaned it all up inc the tube that sits in the manifold but looking down into it there is a ton of gunk in there too which i am not going to attempt to do anything about just now. Might take the manifold off at some point for a clean through with some petrol though.
    So the questions now....having a read a bit it appears that fitting an EGR mod will reduce the build up of gunk on the throttle body etc....can anyone tell me how to do this on my YH engine....read something about a bit of coke can??
    Car has done 41K miles....definitely running a bit smoother with the throttle body cleaned....picks up better from idle too
    Steve
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Hi I just fitted an inline oil catch tank to collect all the gunk comming from the rocker box and going into the manifold, I have just had the swirl valves replaced because the one stuck shut and snapped off, did not want the manifold gunking up again, my next move would be to blank off the ERG, I did it to my 2.5 vec b but had to use a piece of stainless as a coke can got burnt out too quick as it is thin.
    I would like to get an already made plate for mine as well.
    Dec 2011
    Midlands
    Quote Originally Posted by skidmark1 View Post
    What tank did you fit..location etc? Might be best option for me too. want some preventative measure in there to stop it before it causes a problem
    norn iron
    you can get a blanking plate for the z22yh as the egr has coolant running through it on the directs
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Quote Originally Posted by deg View Post
    My bold. Can or can't? Your post makes it sound like the EGR can't be blanked on the Z22YH.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Wheres rushy when u need him it can be blanked on the z22yh quite easily I think
    norn iron
    vauxhall blanked mine off with a proper blanking plate, then tech2 to stop the fault codes coming up. The z22yh cannot be simply blanked off with a piece of tin etc as the coolant system runs through it.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    Post
    Quote Originally Posted by paulvectrac View Post
    So who is right?? can it be blanked to stop emmision gasses from recycling and holes or hole provided for coolant??
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    He's behind you! Sorry its the festive season and all that....
    Yes the yh can easily be blanked, with or without Tec2. Vx can totally take it out of the system for you at a price or you can do it yourself for a couple of quid.
    Im on the phone at the moment, but when im on the pc I'll post up how you do it, think I still have some pics floating about as well.
    Vehicle : SRi
    Mileage : 137000
    Right, you can buy the correct Yh blanking plate from the dealer, its domed in shape to accommodate the YH's cooled EGR system so you cant just make one up yourself.
    Now, you cant just unplug the EGR and blank it as you will get emissions warnings on the dash. What you can do however is blank it but still leave it plugged into the loom. The ECU only monitors the movement of the EGR not the gas flow, so if it can still make the plunger work then all is well.
    The problem you will now have is where to mount the EGR, on the SE its easy because you can just hang it off the side but on the YH you cant because of the shape of the blanking plate.
    Now this is the easy and cheap way to blank the EGR on a YH. There is a pipe that comes off the intake manifold, this pipe bolts to the head. Where it bolts to the head you need to sandwich a home made blanking plate as its this pipe that carries the gases to the manifold.
    This is a picture of a SE head but the position is in the same place.
    #1 in this pic shows the pipe you blanking.
    Hope that helps. Im just off to the Cinema to see Chipwrecked (anyone with kids will know my pain ) so if you have any questions I wont be able to answer straight away.
    PS, this wont give you any more power and it may make you MPG slightly worse but only by 1-2 mpg. If you do this I would still leave the Cam breathing as normal, mine is set up like this and the manifold is clean as a whistle, plus you need a little oil mist to lube your flaps
  1. Z22YH EGR Blanking
    By justathome in forum Engine & Drivetrain
    Last Post: 20th June 2015, 18:38
  2. z22yh remap
    By paulvectrac in forum Petrol Engine related
    Last Post: 8th October 2013, 22:48
  3. Z22YH clutch how much
    By lizard in forum Engine & Drivetrain
    Last Post: 17th June 2010, 21:06
  4. Z22yh....EGR???
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 12:23
  5. Egr - z22yh
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 12:07
z22yh egr blanking plate
egr blanking z22yh
egr blanking pipe z22yh
z22yh egr off
z22yh egr 2006
z22yh engine oil
z22yh throttle body. clean
